Thread: Pool Testing Chemicals - How to tell their age
    Jun 2014
    Scituate, MA
    25
    Does anyone know how to tell how old a pool chemical in the test kit is? They have lot dates, but I don't see any actual dates stamped on them. I think one of the test kits I purchased this year, New from the pool supply store, is actually old. When I purchased the TF-100 and used the K-1000 Taylor kit chemicals they seemed more accurate. I got a higher chlorine count than the other kit and I tested a couple of times.
    Thanks, Patty
    Gunite Pool Inground, Plaster, Built 1982
    20 x 40 paisley, 8 deep end, 3 shallow end, 26,000 gal - 30,000 gal ??
    Filter - Apolo Mode VA 38, 38ft, pressure 50lbs, flow rate 95 GPM, 22 lg., 40 deep, 20 wide
    Model No. C48K2PA105C5, 1 HP 115/230 3450 RPM 60 HZ
    38,305
    Re: Pool Testing Chemicals - How to tell their age
    You have to call Taylor I think to get the dates.
    Or you can find info about how to know when they go bad here: Extended Test Instructions or on Taylor's web site.
