Results 1 to 7 of 7
Thread: Sta rite dyna glas losing flow while vacuuming.
    Apr 2013
    Memphis
    10
    Hello all! This is my first post but I've been here reading all the tutorials and advise from other threads for about a year and a half now, since I've purchased my first home with a pool. So up front, thank you guys for all the information i've gotten already from this website and your collective knowledge!
    So, a little info on the pool and my history with it: Its a 30,000 gallon rectangle at 18'X36' with a small 9' deep end with really steep taper down to it. It was built in the 80s sometime from what I can gather from permits and paperwork the previous homeowner left. It has one main drain at deep end, and one skimmer basket, and one return jet. The return jet is on the far right side of the 18' length while the skimmer is on the far left.. This produces kind of a horse shoe flow on the surface for skimming, and that seems to work alright.
    It has a 1 HP Sta rite Dyna Glas pump.
    sand filter: Hayward 3.14 SqFt, 20GPM/SqFt, 63 GPM "design flow rate"... (Model S-244T if it helps anything)
    I added a salt water chlorine generator first thing before even observing it on (other than the pool inspection when I didnt know what I was looking for). It is a Pool Pilot; auto pilot digital.
    All PVC piping is 1.5" except the SWG which was 2" from factory so I had to neck up and back down to accommodate it. Here's a picture of the set up before and after if it helps.Attachment 32138Attachment 32139 .
    Notice I had to use several additional small bends to get it to line up and the rise on the cell orientation no doubt added resistance. Not sure if any of this hurt my cause.
    With all that pertinent information out of the way, the problem: When the 3 way valve is open to both main drain and skimmer, this problem doesnt exist, but when I shut it to only suck from skimmer and start vacuuming, I lose flow gradually over the course of about 10 minutes. The pressure on my gage never rises, rather drops as the flow reduces. I can prolong this from happening by unscrewing the jet eyeball thing while vacuuming. Once the flow stops though, I have to stop, got shut the pump off, and wait a minute. After turning it back on it seems to have regained its flow, i reattach the skimmer plate and continue to vacuum for another ten min until I repeat the cycle over again.
    When it does this there is still no additional air (i've fixed all suction air leaks I think, and have a constant small bubble in the top part of the lid where the handle is. Seems like its just trapped up there at the high side.).. So its full of water, but it seems like the impeller is just spinning in the water and i guess just not having 'traction'. I can't hear any cavitation but I may wouldnt since the pump isnt all that quiet in the first place.
    Things I've done to try to help this inside the pump is replacing the o-ring on lid, assuring impeller is clean, I noticed the previous owner stripped out the inserts holding the diffuser in place so I retapped those and have the diffuser held firmly in place now with 1/4"-20 stainless screws. The o-ring on the nose of the diffuser has not been replaced and doesn't look great. Pool store says that if that was the cause it wouldn't slowly degrade, it would just never prime. The impeller has a few stress lines, but not any breaks or large cracks that I can see.
    So in short, I'm baffled by why the flow would just stop like that while pressure decreases. The filter does not require a backwash to get it going again either. I've never seen pressure go up on the filter the 10 PSI that everyone says should be my indicator to backwash actually, in any valve setting. It just sits around 12 PSI at all times.
    So, I know that was a really long post and sorry about that, but any help or advise will be greatly appreciated. Thanks so much in advance!
    Memphis, TN.
    30,000 in ground rectangle Pool
    Salt water converted with Pool Pilot auto Pilot digital
    Hayward S-244T Sand Filter - 3.14 SqFt / 300Lb sand
    Sta Rite Dyna Glas pump - 1HP motor
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: Sta rite dyna glas losing flow while vacuuming.
    My guess is that you have a small air leak in the vacuum hose.
    Apr 2013
    Memphis
    10
    It is a new hose, but I wouldn't doubt that an air leak is impossible based just on that. My main curiosity surrounding that specifically is this: if its an air leak in the hose, wouldnt I just get a bunch of air in the line and lid and lose prime instead?
    Memphis, TN.
    30,431
    What is the psi when both main drain and skimmer are open?
    What is the psi when only skimmer is open?
    As psi slowly diminishes as you describe, how low does the psi get before air fills the pump basket and you are no longer able to pull suction?
    This is of course related but doesn't make sense, a reduction in the flow of water means your gauge has to change one way or another.
    What does your pool water look like? Are you pumping dirty water?
    Apr 2013
    Memphis
    10
    As psi slowly diminishes as you describe, how low does the psi get before air fills the pump basket and you are no longer able to pull suction? This is of course related but doesn't make sense, a reduction in the flow of water means your gauge has to change one way or another.
    That's the kicker. The PSI is 12 with both skimmer and main open, or with either one closed and the other open. When the psi slowly diminishes, the PSI goes down to zero, but the basket never fills with air.
    Pool water looks great, since without a load such as a vacuum it flows fine... again, at 12 PSI constant.
    Memphis, TN.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Does the gauge go to zero when it's off? Drops right down fairly quickly?
    Apr 2013
    Memphis
    10
    Yes it does, the gage is also new this season for good measure.
    Update though, I looked again and do see a pressure drop of about 2-3 PSI when I cut off either skimmer or main drain. Flow remains however. I'll vacuum again this weekend and provide a detailed report of the flow and pressure degradation.
    Memphis, TN.
