Thread: Bubbles in pool
    Bubbles in pool
    Split and merged by moderator. Please always start a new thread instead of asking questions in another member's thread ... which it looks like you did. Thanks, jblizzle
    Hey new to the site. I used Clorox bleach for the first time and now I have some bubbles. Plus pool isn't looking to clear. What do I need to do to fix this. I have a party this weekend and not sure what to do. I also have floating chlorine tablets in the pool as well. HELP!
    Jun 2014
    Douglasville, GA
    53
    Re: No Free Chlorine - Please help!
    Hi Chas, its best to start your own thread, that way you can get specific help for your situation. Please read the top two posts first, they will help you to help us.
    33K gal vinyl IG, 1.5 HP SuperFlo pump, Hayward S244T sand filter (62GPM)
    Bubbles in pool
    Hey new to the site and trying to get some answers to fix my pool problems. For the first time I used Clorox bleach in my pool. Now I have bubbles, the pool isn't clear and it seems to have a film like presence. I have a party this weekend and I need HELP! Just think about draining and refilling.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Bubbles in pool
    Welcome to TFP!
    It sounds like you don't have enough chlorine. What are your test results?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Re: Bubbles in pool
    Welcome!
    Is there any chance you bought "Splashless" or "High Efficiency" or "Outdoor" or "Scented" or some other boutique Clorox? Whatever it is they put in that stuff, it can cause suds. They will go away if you keep the FC level up with plain Clorox or its equivalent.
    If the pool is greenish, foaming is common when algae starts dying. Does it look like this?
    So tell us what the water looks like, what you've added, and test results and where they came from.
    38,489
    Re: Bubbles in pool
    Specifically what bleach did you use? Was it splashless or outdoor or something?
