Thread: Is this a calcium deposit?
    Nov 2013
    Fort Worth, TX
    114
    I have a white, hard growth in a particular are of the pool. Can you tell me what caused this; how I can get rid of it; and what to do to prevent it.
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,014
    Re: Is this a calcium deposit?
    That is called efflorescence. Moisture behind is coming through and carrying Calcium with it. Use the search box for efflorescence and you'll find some posts by people who know more than me.
