Results 1 to 9 of 9
Thread: New pool finally installed! Updated with some pics!
    MadMarty's Avatar
    Jul 2013
    Massachusetts
    13
    Hi everyone! Finally had my pool installed yesterday and it looks great! Here are a few shots of the install.
    This barely made it through the gate!
    Let the water flow!
    I took some water readings (city water) as I started filling it up:
    About 18in of water currently
    CL .5
    PH 7.5
    FC .5
    CC .5
    TA 30
    CYA 0
    Do you recommend that I add some bleach or cya while it is filling? Looks like I need to add quite a bit of Baking soda for the alkalinity? It may take another two days to fill completely. I am going to wait and add salt when it is full.
    18,000g AquaLeader Harmony resin round 27' 54" AGP, Pentair EasyClean DE 60, Pentair Optiflo 1.5hp, Circupool Si30+ SWG, TF-100 kit, Dolphin S50 Robotic Cleaner
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: New pool finally installed!
    I wouldn't add anything until it's full and circulating.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    MadMarty's Avatar
    Jul 2013
    Massachusetts
    13
    Thanks crazy! I will wait until it is filled... should only be another day or so.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: New pool finally installed! Updated with some pics!
    If it was my pool, I'd calculate the volume when it was a foot deep and pour some bleach in the hose stream to get it to 2 or 3 ppm, just as cheap insurance. And again the next day if it still isn't full. It won't last long, but it'll take care of any organics that blow in while it's filling. I know it would give me great piece of mind.
    Once it's circulating for half an hour, recheck pH and TA, and adjust as needed. Work up to your levels, because baking soda will have some effect on pH and borax/washing soda will affect TA. So if you add everything poolmath tells you to at once, you'll overshoot. So go halfway to your TA target and recheck pH and then adjust things accordingly.
    While that stuff is mixing, you can busy yourself with the CYA granules and the sock. And once the pH and TA are good, add some more bleach, realizing your effective CYA level will be zero for all intents that soon after adding. Then let the kids in.
    MadMarty's Avatar
    Jul 2013
    Massachusetts
    13
    That's great advice Richard, thanks. I will calculate the volume when I get home from work and add some bleach as a precaution.
    MadMarty's Avatar
    Jul 2013
    Massachusetts
    13
    Well, all is going well! The pool is fantastic and I have gone ahead and hard plumbed everything! Looks great.
    Jul 2014
    Hudson Ohio
    142
    Looking good. I an so hard piping my pump in the spring. It looks so much cleaner.
    What is the device in the return line and the white box on the power pole?
    24'x54" AGP 13,500g AquaLeader Sentinelle | Hayward Voyager CC150 sqft cartridge filter | Hayward 2hp 2spd pump | Hayward Aquaray Cleaner
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Quote Originally Posted by mrramsey View Post
    SWG and controller, respectively.
    Jul 2014
    Hudson Ohio
    142
    Ah OK... I am letting my noobness shine through.
