Results 1 to 9 of 9
Thread: Hayward Wall Skimmer Leaking Intex UltraFrame Pool
    Jun 2014
    Baltimore, MD
    18
    Unhappy Hayward Wall Skimmer Leaking Intex UltraFrame Pool
    Yesterday evening I upgraded my Intex sand filter from the 1600 GPH model to the 2650 GPH model installed a Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer and Accessory Kit. I have the Intex UltraFrame 12x24x52 pool and the installation seemed to go smoothly except now it is leaking.
    Initially I drained the pool down about 6-8 inches to install the skimmer without water leaking. I placed the skimmer just below the liner "edge", marked the screw holes with a sharpie, punched the holes, and then screwed the skimmer on. At that point I cut out the opening for the skimmer using a box knife. I installed the butterfly gasket without cutting it in half like some others have done. I screwed the face plate, gasket, and skimmer together and start adding water. I noticed that now I have a very small stream of water running out from the bottom of the skimmer down the outside of the pool so I stopped adding water (it was getting late last night).
    Has anyone had this issue and successfully resolved it? I was thinking I should try using some silicon sealant but I wasn't sure what to buy and if I should put it under the gasket or what. I tightened the screws to the point that the gasket started to "squish" out a little and I felt like I was going to crack the plastic so I think it is pretty tight.
    Thanks in advance!
    Aug 2011
    Cochranville, PA
    228
    Re: Hayward Wall Skimmer Leaking Intex UltraFrame Pool
    Everyone is going to ask for a picture. Could the gasket be on wrong side of the liner?
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    May 2014
    mi
    27
    I had the same problem. I could not believe how much I had to tighten the screws to get it to stop leaking.
    Did you tighten only one screw at a time or did you do each one a little and then move on to the next?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,554
    Mine also leaked a bit at first. I tightened the snot out of it using a screwdriver bit inserted into a socket wrench, and it's all but quit now. Just a slight seep that I ignore.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2014
    Baltimore, MD
    18
    I didn't cut the butterfly gasket so its on both side of the pool liner/wall. So I tightened the screws a little more but it still was a very slow leak. I bought a small tube of bathroom silicon sealant and put it around the outside of the skimmer/gasket/plastic on the outside of the pool and no more leaking. It was such a small leak I probably didn't need to worry about it but I am a perfectionist. FYI I used the following silicon that I applied to a slightly wet surface but so far it is holding: http://www.homedepot.com/p/GE-Silico...-3TG/100004845
    Intex Ultraframe 12x24x52, Krystal Clear 3,000 GPH Intex Sand Filter, Hayward SP1091 Wall Skimmer, Aquabot Pool Rover ., Confer A-Frame Safety Ladder Model 7200
    jmcdtucson's Avatar
    Jun 2014
    317
    Lower the pool so it's no longer leaking and apply Marine Goop?
    I don't think any sealant will work while it's actively leaking.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Jun 2014
    Baltimore, MD
    18
    Quote Originally Posted by jmcdtucson View Post
    I appreciate the product recommendation. Right now the leak is so slow and minor that its probably a gallon a day so I'm not going to concern myself or lose any more pool time working on it. Come next season (since I tear down and put up the pool every season) I will check out the Marine Goop. To my knowledge the Intex Ultraframe pools aren't supposed to stay up through the winter if freezing is expected and in MD we get some really cold weather from time to time.
    jmcdtucson's Avatar
    Jun 2014
    317
    Sounds good. Keep in mind I haven't done this. Just used Marine Goop to seal lots of things from kayaks to evaporative coolers.
    Also lots of people winterize their pools and leave them up. Just search this site for 'winterize'. I'll probably do that, but we don't have many hard freezes here in southern Arizona.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    I am going to give you the same advise I gave you in the other thread. Get a #3 Philips instead of the standard #2 and use the extra torque to give you that little bit of extra umph on those screws and you won't have any need to smear something all over the skimmer and your pool. I know they were making a nasty popping/clicking sound that scared you. Mine did and I got nervous too. But those screws have #3 Philips heads because it is necessary to have the extra torque to get the gasket to seal. I haven't done really extensive research on this, but I don't think I have read of anyone busting the plastic from over tightening. However, I have read more than one post of people who thought they had the screws tight but didn't quite have them seated.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
