Thread: How to wait after adding liquid chlorine to go in swimming?
    Jun 2014
    Scituate, MA
    25
    Hi,
    I would like to know how long I should wait before swimming if I add liquid chlorine to the pool.
    I'm trying to keep the level up to my CYA and it's sunny, hot and humid this week.
    Thanks, Patty
    Gunite Pool Inground, Plaster, Built 1982
    20 x 40 paisley, 8 deep end, 3 shallow end, 26,000 gal - 30,000 gal ??
    Filter - Apolo Mode VA 38, 38ft, pressure 50lbs, flow rate 95 GPM, 22 lg., 40 deep, 20 wide
    Model No. C48K2PA105C5, 1 HP 115/230 3450 RPM 60 HZ
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: How to wait after adding liquid chlorine to go in swimming?
    Quote Originally Posted by PattyA View Post
    Hi,
    Thanks, Patty
    20-30 minutes with the pump running should be sufficient time to circulate teh chlorine around. That is assuming the level is below your shock level
    Support the site
    Jun 2014
    Scituate, MA
    25
    Thank you, that's perfect.
