Thread: Phosphate problem???
    Curtsam's Avatar
    Aug 2013
    Eastern Oklahoma / Arkansas
    33
    I found this old thread of phosphates and would like for you to confirm with me again that my high phosphate level of 2500 is not a problem. I have been using my TF 100 Test Kit (love it) and being a newbie I wanted to ensure that my numbers were right. Took the sample to Leslie's ( got their sample bottle for my own use! lol ) and everything looked great except the phosphate level.
    Thank you in advance,
    Sam
    2014, IG 20,000 gl 18x34 Vinyl Liner / Waterfall / SWG / Sand Filter /
    Dolphin M4 Robot / TF-100 Test Kit is used / Beer is consumed /
    *Stamped Concrete Decking*
    Donldson's Avatar
    NW Ohio
    2,893
    Re: Phosphate problem???
    From another post on the subject:
    Quote Originally Posted by Donldson View Post
    Phosphates are ... let's call it a large field of dry grass. If there are sparks falling on this dry field, which is easier, removing all the grass or saturating the field with water? Keeping the FC at an appropriate level for your CYA will keep the hypothetical field wet and it doesn't matter how many sparks fall on it, it will not catch fire. So yes, phosphates are algae food, removing it could help slow algae growth, but phosphate does not matter if the algae dies before it can eat.
    Phosphate removers have a large profit margin, so it's not to hard to figure out why pool stores love to push them.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    As you suspect, keep your FC in line and no need to worry about phosphates.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Curtsam's Avatar
    Aug 2013
    33
    Thank you!
