Results 1 to 7 of 7
Thread: Pool Motor blew up
    Mar 2012
    Maryland
    87
    Pool Motor blew up
    So I switched on my pool pump. I saw red sparks shot out the back and my GFCI tripped. I reset the GFCI and turned the motor back on, this time it came on but moved slowly as well as smoke was coming out the back.. I was thinking it was a capacitor or something. I took the motor apart and found there was no capacitor. I looked at the winding and found part of the winding was black and burned. I have the following label information
    A.O. Smith
    CAT BN25SS
    Type SP
    FR W48Y
    1 HP
    1 SF
    12 AMPS
    3450 RPM
    I'm thinking of getting a new motor, I saw them on ebay but the price is high (124 is the cheapest I found). Also I notice the newer versions of these motor operation on lower AMPS (like 7 or 8). Is the amps listed on the old motor the maximum amps or are the newer motors more efficient?
    I also notice they sell 3/4 HP motor with the same RPM? Would it make better sense downgrading the motor if these motors both run on the same RPM?
    13,500 gallon above ground round pool. Vinyl Liner. Hayward S244T 3.1 cu ft sand filter. Hayward Powerflo 1HP pump (single speed induction). HTH 6-way test kit.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: Pool Motor blew up
    The 3/4 hp motor will overheat unless you also get a 3/4 hp impeller. The impeller is around $35.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    If the 3/4 HP has a SF greater than 1.4 you'll be ok. You're concerned with the THP (total HP or SFHP), which is SF * HP.
    SF * HP = THP. 1 * 1 = 1
    so if you replace your motor with a 3/4 HP you'll want the one with a 1.65 (standard) service factor.
    Some reading: http://www.troublefreepool.com/threa...ce-Factor-quot
    Last edited by bobodaclown; 07-22-2014 at 03:54 PM. Reason: Not Brake HP but Total HP or SFHP.
    Jul 2011
    Perrysburg, OH
    88
    That price is actually pretty good. I just got a 1 HP for $134. Also check Amazon, they have good prices and customer service.
    38,475
    Why not take the opportunity to upgrade to a 2-speed motor and save money on electricity? Will cost a little more upfront, but will save over the life of the motor.
    Apr 2011
    Murrieta, CA
    2,360
    Looks like you're limited with the motors your able to get.
    The 1HP two-speed motor you'll need looks to be the BN37, should be less than $200. Running on low will save you money. I've gone from a single speed to a two-speed and am very satisfied. (I use a robotic cleaner, not a pressure cleaner). I run 95% of the time on low.
    https://www.google.com/search?q=bn37+motor
    You'll need a switch to go from High/low.
    Mar 2012
    Maryland
    87
    Quote Originally Posted by bobodaclown View Post
    How long do these motors typically last? Also has anybody successfully rewound a motor? I see you tube videos of people rewinding several small motors.
