Thread: Chlorine Content
    Jul 2014
    Tulsa/OK
    2
    Chlorine Content
    I have a new pool and the builder convinced me to get a UV and ozonator installed which disinfects....
    however, I keep testing the water and my CL content is 0, Does the UV burn off the chlorine?
    My water is clear and everything appear to be working well. It is a salt pool so the pH takes some work but the rest seems vertually maintenance free. I figure the CL has to be OK but 0 to 0.5 seems concerning.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Chlorine Content
    Hi, welcome to TFP! Please post a recent set of test results, it will help us trouble shoot the problem. UV does break down chlorine. Is this an indoor pool?
    Love TFP? Become a
    TFP Supporter!
    We don't recommend either UV or ozone on a residential pool. Both of them consume some chlorine, as does sunlight. If you post test results we can give you more specific advice.
    Jul 2014
    Tulsa/OK
    2
    28,000 gallon outside residential pool
    Free CL 0
    Total CL 0
    Combined 0
    pH 8
    Hardness 160 ppm
    Alkalinity (w/stabilizer correction) 135ppm
    Cyanuric Acid 50ppm
    Salt 4000
    This pool is 5 weeks old.
    38,267
    Please add your pool details to your signature as described HERE as it will help us help you in the future.
    You also need to invest in one of the Recommended Test Kits and start doing your own testing if you want to take control.
    That is not good that the FC is so low. Our recommended FC levels do not change based on having UV or ozone.
    Your CYA is a little low (if you believe the pool store testing, we do not) for a SWG, but I might hold off on adjusting that.
    How long do you run your pump/SWG? What is the SWG % output?
    I would lower PH to 7.2. Try to keep the PH between 7.2 and 7.8. With a SWG and high TA the PH will tend to go up all the time. Each time PH gets to 7.8 you can lower it to 7.2. Long term that will lower TA, and reduce the amount of PH drift you experience.
    You need to maintain the FC level one way or another. If the SWG doesn't take care of it, you need to add chlorine manually.
    FC going down to zero usually indicates a need to SLAM the pool, see the instructions in the How To section of Pool School.
