Results 1 to 7 of 7
Thread: Help with Returns please
    We have a lazy L shape inground pool. It is 8ft in the deep end. The skimmer is on the long side of the pool, mid-wall in the deep end. The returns are both on the short side in the deep end. I'm attaching a drawing.
    Question - what is the best way to aim the returns. We have trouble getting debris from the shallow end into the skimmer. We can't face the eyes up too far. The Ph is constantly HIGH.
    Thanks for your suggestions!
    25,000 gallons - sand - IG vinyl - 1.5 pump - 50 filter - installed June 2012
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Help with Returns please
    Which way does the wind predominantly blow? Use that to your advantage. Not having any returns in the shallow area makes it more difficult. Not knowing the way the wind blows, I'd say aim towards the deep short wall to get the flow clockwise.
    Most wind comes from shallow end, toward deep end. But we don't have too much wind. We are kind of shielded on most sides.
    Do I want to point them the same or opposite ways? If I don't point one to the shallow end, I feel like the water there gets no circulation. But then the skimmer is not very effective.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Best thing to do is experiment. Throw a handful of ping pong balls (on a windless day) in various places and see if they end up in the skimmer. I would probably first try just aiming the returns toward the skimmer wall (i.e. straight).
    If the balls collect in the shallow end, then you might try pointing the return closest to the shallow end toward the opposite corner. The other solution would be to put in a 90 return like this:
    Mark
    Apr 2011
    Murrieta, CA
    2,360
    Mark is the resident expert. I default to him.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Pointing returns is kind of hit and miss so no amount of expertise in any area is probably going to help. The more ideas the better. I say try them all.
    Mark
