Thread: Phosphates ???
    Jun 2014
    Scituate, MA
    25
    Phosphates ???
    Hi,
    Just had pool supply store do chemical analysis.
    Pool Supply My readings
    FAC 2 FC 2-4
    TAC 2
    CH 260 CH 225
    CYA 50 CYA 40
    TA 100 TA 80
    pH 8 pH 7.6-7.8
    Acid Demand 2 ?
    Phosphates 200
    I just did my own testing. My questions is about Phosphates, what are they and their effect on pool water? Pool company suggests Phosphate Free to add. Also, Dry Acid to reduce pH.
    Thanks, Patty
    Gunite Pool Inground, Plaster, Built 1982
    20 x 40 paisley, 8 deep end, 3 shallow end, 26,000 gal - 30,000 gal ??
    Filter - Apolo Mode VA 38, 38ft, pressure 50lbs, flow rate 95 GPM, 22 lg., 40 deep, 20 wide
    Model No. C48K2PA105C5, 1 HP 115/230 3450 RPM 60 HZ
    38,415
    Re: Phosphates ???
    They are a way for the store to make money. Ignore them and maintain proper FC levels (which you are not btw)
    Search the forum for many discussions about them.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Phosphates ???
    Check out Post 10 for an excellent explanation: http://www.troublefreepool.com/threa...ow-Im-confused
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Phosphates ???
    Phosphates are algae food. They can contribute to faster algae growth. But if the phosphate restaurant is closed due to adequate FC levels, it doesn't matter how much food is around. Phos Free is a waste of money in a properly maintained pool. Your FC should ALWAYS be 3 or above at 40 ppm CYA.
    Your pH is in normal range, if it creeps to 8, then reduce to 7.4. I would recommend muriatic acid over dry acid as it's cheaper and adds less chemical species to your pool. It does require more caution when using though. Based on your levels your pH is ideal between 7.4 and 7.9.
    Isolated Spa - 345 Gallons
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Re: Phosphates ???
    Quote Originally Posted by JVTrain View Post
    It has been mentioned in the past that phosphates can also be suspected in relation to mustard algae it seems to be the only connection why some pools get it and some don't. Chem-Geek has covered this... he can speak on the subject more.
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
    Donldson's Avatar
    NW Ohio
    2,913
    Re: Phosphates ???
    Now that is praise from on high
    Not sure why you are getting pool store testing. If just curiosity then hope it is satiated. If you are trying to verify your results, don't. The tests in the recommended kits are the most accurate available. Yes, even the CYA test. Just remember, phosphate removers have very nice profit margins. Can't imagine why they push them so much
    From myHTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
