Thread: Upgraded and Swapped all our IC40 to IC60
    susa's Avatar
    Oct 2010
    Deep South
    578
    We have a few family pools that all run on pentair equipment and while we typically run our pumps for 6 to 7 years, we replace unconditionally the IC40 SWCG cells every 3 years or when warranty runs out.
    Same for the pentair cartridge filters, outer case and media. This saves us time and maintenance plus we pickup new warranty for another 3 years on the replaced parts.
    Just swapped out perfectly working slightly over 3 years IC40s for IC60s. Price from local wholesale outfit was only usd 40 more for the IC60 and it fits into union without any mods.
    Tested each of the IC40s in a bucket before disconnect and they foam up the water nicely showing the cells still generate, cells are also totally free of any deposits.
    Jun 2011
    Long Beach, CA
    2,787
    Re: Upgraded and Swapped all our IC40 to IC60
    Are you trying to sell them? About how many hours do the cells have on them? Cells running at 100% for 24 hours a day for 3 years is a lot different than one running at 50% for 6 hours a day.
    Post it in the coffee bar and someone might be interested if they are cheap enough. That or save them so if you do have a failure you can plug one in until the cell is replaced under warranty.
