Results 1 to 16 of 16
Thread: Video showing how clear your pool can be!
    May 2014
    Clarksburg, WV
    331
    Here is a video of my son in our pool.
    He wanted me to film him jumping in and touching the bottom with both hands...lol
    Not a speck of algae anywhere. Been that way all season. Thanks to this site.
    Clear Pool!!!
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Jul 2014
    Medina, Ohio
    55
    Re: Video showing how clear your pool can be!
    Awesome!
    My kids are having a blast in our newly-opened pool, too. We have just about the same equipment, and I'm on the TFP method too, using Pool Shock 12.5% bleach and monitoring daily. I can't believe how clear and clean our water is staying. I do have two suction-side inlets (bottom drain and skimmer), so that probably is helping the circulation and filtering. I leave my 2-speed pump on Low Speed most of the time, and the filter and skimmer does the rest.
    Couldn't be happier so far!
    17,100 gallon, 27' round Wine Barrel, Hayward Matrix 1.5HP 2-speed Pump, Hayward Pro Series 24" Sand Filter, Hayward Skimmer and Returns, TF100 test kit......and lots of labor!
    Casey's Avatar
    SW PA
    10,453
    Spectacular Kris! My water has been just as clear since I filled it last summer! TFPC ROCKS!
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Great Job! My pool has also been crystal clear since finding TFP pool 5 years ago.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Gotta love it. My wife was skeptical, but she has been blown away by the ease of keeping this pool up. Which reminds me...I gotta make a bleach run today.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Isn't it AMAZING? Bet it looks like glass on a sunny day, and empty at night under the light of the moon.
    I'd love to see you do a video on a bright sunny day.
    What video camera did you use? GoPro?
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    May 2014
    Clarksburg, WV
    331
    I have an older Kodak Playsport. It does the job, but when water gets in the mic, it distorts the sound a bit.
    Seems crazy. My in laws have a pool and they go by the pool store. Theirs was crystal clear for the first half of the season. Then we had about 3 days of rain. They took the cover off yesterday and the bottom was starting to turn green. I took the cover off mine and it was just as clear as it was 3 days ago. I tried to tell them when I first started this that I was going to use bleach and they gave me a real hard time about it. Saying it would bleach my liner and cause damage to everything. The only thing i see fading right now is my rubber duck thermometer....And that would probably happen with any chemicals.
    Only thing i've had to do is add bleach. PH has stayed between 7.2 and 7.5. TA stays around 100-110. Add about 40oz of 12.5% a day and i'm good.
    I even used a puck or two while taking a trip last week and everything stayed like it should have. I needed to add some CYA anyways so i figured why not use the free pucks they gave me at the beginning of the season.
    Thanks to all on this site who helped me get started. Hopefully more videos will be coming soon.
    TF-100 Test Kit
    How to SLAM
    Jul 2014
    Medina, Ohio
    55
    Kris77 -
    I am also using the TFP system and couldn't be happier. I filled my pool with my normal city water, and have had great success. PH was 7.2 - 7.5 and TA was 110 right from the hose. I haven't had to add anything to adjust it. I then added enough CYA to bring it to 50-60, and it's been smooth sailing since.
    My pool seems to like a "diet" of about 26-32 oz of 12.5% Pool Shock (bleach) to keep the FC up around 7 to 8. I'm curious why your pool seems to like about 40 oz daily? Do you like to keep your FC higher? Or maybe a heavier swim load? I'm curious because your pool is a little smaller in volume than mine, I would expect you to need a little less 12.5% than I do....hope I'm not missing something and not adding enough to mine!
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Augie56,
    I would say you're losing about 1.5-2ppm FC per day, and Kris77 is losing about 2.5ppm per day.
    The OP either has a lower cya, as you're higher than most here, but well within recommended levels, or has more bather load, like you suspected.
    I'd say you're both doing REALLY GOOD on your FC loss, assuming the weather and water are quite warm, and your pools get good amounts of sun where you are.
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    Quote Originally Posted by Augie56 View Post
    Awesome!
    Dang, having a blast in such a cold summer! We haven't been in the pool since early June. Other than the last 2 days, I don't think we've been at 80°. Water temp isn't going to recover with just 2 days of 85 and close to 90°. I haven't looked, but judging from having my hand in the water yesterday, it was 88° outside and water temp was probably 72°.
    ....using Pool Shock 12.5% bleach and monitoring daily.
    Austins? Love that stuff. It's a steal at $3.89/gallon. I don't know if you get Austins out your way, it's a local western PA company. Gallon jugs of 5.25% is just $1.89 at a little local hardware store and the 12.5% Pool Shock is $3.89, or I think might be a few pennies less than that. It ends up the same price per unit of chlorine whether I buy the bleach or Pool Shock, but sure makes it easier to use the 12.5%.
    And love the video in the thread creator. My water is crystal clear, but the filter isn't doing a very good job of catching the sediment. I vacuum and it's back the next day.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    Jul 2014
    Medina, Ohio
    55
    I hear ya about the cool summer, although me and my kids don't seem to mind too much.
    My wife, on the other hand, is a baby and only went in yesterday when it was sunny and 87 deg outside!
    The 12.5% Pool Shock is from the Ace store nearby, and I get four gallons for $15.99, so I think it's not too bad of a deal.
    My pool gets full sun all day, and there's no trees nearby, so that helps too. Just wanted to be sure I wasn't missing or overlooking something!
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by kris77 View Post
    thats classic of a pool stored pool. Im not sure what causes it, maybe FC too low, CYA too high... maybe both, but every person I know with a pool stored pool dreads the rain because they go green every time. I wake up and see it raining, my biggest concern is: How am I going to test and put in my chlorine without getting wet?
    boy! that is some crystal clear water you got! awesome!
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    May 2014
    New Jersey
    30
    That pool looks awesome, WOW..
    Mine is not there yet, but I'm a rookie, so still at it.
    I believe my 19"/100lbs sand filter might be a tad small for my pool.
    When and how long do you guys run your filter? I get full sun, no trees around.
    13,500 Gallon 24' x 52" AGP
    Hayward DE EC50 w/1.5HP Pump
    Taylor K-1004 Test Kit
    Intek 2014 SWG - Copper Disconnected
    May 2014
    Clarksburg, WV
    331
    I run my filter on low during the day and then turn up to high when I add FC and leave it on high all night. When i get up, its just part of my day to turn it back on low. I probably run it too much, but it doesnt bother me at all.
    And to answer an above question, My CYA is a little lower than 50-60. I need to shoot for 50, but this late in the year, i'm just going to keep going like I am. Next year i'll shoot for 50. I get Full sun from about 8am-7pm roughly. No trees around.
    Two days ago I messed up my FC test and overdosed and had a FC of around 9.5-10. One day ago, it was 7.5. Last night it was 6.5. I havent added FC in 3 days. Have had swimmers last 2 days. I thought that was pretty amazing to not have to add for 3 days and swim 2 of them. I'm sure i'll have to add tonight though.
    And I get mine from Ollies...12.5% for $2.99. Cant beat that.
    And to mrogers, my pool was 85 last thursday. Rained sunday and monday and was cold the weekend. Highs didnt even hit 70 one day. Water temp was down to about 76-77 Monday morning. It was 79-80 Monday evening when i swam and that video was taken, and it was 81-82 yesterday... 77 is pretty cold for me. 79 was chilly, but it felt good after I got used to it.
    TF-100 Test Kit
    How to SLAM
    Jul 2014
    Medina, Ohio
    55
    FWIW, I run my pump on Low Speed almost 24/7. My two return jets create a nice slow swirl of the water, right past my skimmer before getting back to the first return jet. Anything that sinks get swirled to the center, where my bottom drain is. Seems to work well so far. I only run my pump on High Speed when I backwash or vacuum. The pump on Low Speed is less than a 3 amp draw, and it's virtually silent. The 2 speed pumps are worth the little bit extra they cost.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Quote Originally Posted by mrodgers View Post
    Aren't those Intex cartridge filters a blast? Try adding d.e. alternative cellulose powder, prepare for many cycles. Also 2 pairs of nylons over the cartridge. Lastly, don't clean it as much, or as well each time... filters better.
    Sand filter up and running soon, and GOOD RIDDANCE! to this Intex cartridge filter+pump. I have fought with it for 3 seasons now, I'll be glad for the upgrade I worked hard for.
