Thread: Suggestions - Finish With Well or Truck in?
    Jul 2014
    Northern Minnesota
    51
    I started filling my 3,000 gallon AGP today. I have approx 1,000 gallons in it right now. I am running it through my soft water system so every 1,000 gallons I have to stop and let the system regenerate. It takes about 2 hours to fill 1,000 gallons. I didn't get started until about 3pm today. As soon as I was done with the 1,000 gallons I got a call from a trucking company who will fill my pool for $150 (all 3,000 gallons or whatever is left over - same price).
    My question is:
    1. Should I just finish with the well water (it has a slight tea color even after running it through the system)?
    2. Should I leave the 1,000 in and let the truck company fill the remaining 2,000?
    3. Should I dump the 1,000 in the pool (it won't flood my yard or any area) and let the truck company fill the whole 3,000 gallon pool (the truck company uses city water)?
    Any suggestions would be great. Thanks!
    Intex 15 ft x 42" Above Ground Pool bought from Amazon (3, 284 gallons)
    Standard pump and cartridge filter that came with the set up (1,000 gph)
    I live in Northern, MN
    Aug 2011
    Cochranville, PA
    228
    Re: Suggestions - Finish With Well or Truck in?
    I can't answer 2 or 3 but... My parents have a bad well and when the water changes color it means they are going to run out of water soon. My well on the other hand is awesome! I fill every year about 5000 gallons. What I do is turn the hose to about half stream and let it go till it is full. I also don't stop to regenerate. You are going to have to adjust your levels anyway. So I would slow down your fill water and it will be full when it's full.
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
