Thread: Estimated daily CL loss question
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    I have estimated that I lose approx. 5ppm of CL a day with the weather has hot and muggy as it is. My question is, I just tested my CL/FC it's approx 7.50ppm and CC was .5. If I don't add bleach in tonite, I am sure by tomorrow evening when I test my CL level will be below the min. 4-6 ppm range that I need to keep the pool in. How is this handled? should I add some bleach now or should I just wait until tomorrow morning to test and then add in the evening if I am below 4ppm?
    BTW I BEAT that algae bloom from last week,pool is back to normal. Whew!
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Re: Estimated daily CL loss question
    There are many different ways to deal with this. The simplest is to raise the FC level once a day in the evening. Raise the FC level to whatever level it takes to still be at your desired FC minimum the next evening. After a couple of days of trial and error you should be able to figure out what that is.
    Casey's Avatar
    SW PA
    10,461
    I usually lose 2-3 ppm a day. Last night I was at a healthy 5 ppm but I know by this evening, if I didn't add last night, I'd probly be below my minimum.
    I usually bump it up to 7 or 8 each night.
    I'm glad to hear you got the pool cleared up!
    Oct 2007
    Central Texas
    104
    If its not too much trouble, what is your CYA level? It will have a direct effect on how much chlorine you lose each day.
    Light grey plaster, stone coping, 38K gallon Roman shaped pool with a shallow end beach, table and bar stools, deep end bench and waterfall (Intelliflo 4X160). Taylor K-2006, Pentair 320 chlorinator, Intelliflow VF, Quad DE 100. 4 ColorLogics, 3 skimmers, 14 wall returns, 13 floor returns, TurboTwister slide, autofill and miles of pvc.
