Thread: Using Taylor drops with a "Basic 5" test kit??
    Jul 2014
    Tampa, FL
    1
    I have had a basic 5 test kit, got some drops by Taylor from another pool store, and my readings don't seem correct. I think the volume/capacity of the vials I have may require different amount of drops, and the Taylor droppers don't have instructions. I cannot find what the capacity is for my existing Basic 5 vials. I have the R-0014 ph Indicator and the R-0600 choroline (orthotolidine) droppers. For my Basic 5, I would used 5 drops of the Orthotolidine...use the same number drops of R-0600? For the ph, I would use 1 drop neutralizer (I still have some from my original kit) followed by 5 drops of the ph solution. Thanks in advance for any insight on this...what I am seeing is that my cholorine levels look very good, but I haven't added chlorine in a while, so I would expect it to be low. Also, my ph is showing that I need to add ph stabilizer. Thanks.
    Re: Using Taylor drops with a "Basic 5" test kit??
    Welcome to TFP!
    When using the Taylor PH test reagent you add enough drops to get a clearly visible color, the exact count isn't important. Also, you do not use chlorine neutralizer first.
    The same basic idea for the Taylor OTO reagent, enough drops to get a clearly visible color.
    May 2013
    New Jersey
    64
    I would also like to k ow this- I found my chemicals but misplaced my kit so I would like to know how many ml of water to mix with 5 drops of R-0600 and R-0014.
    Thanks!
    Bernie
    Bernie
    20,000 Gallon (16 x 32), IN ground, Vinyl Pool
    Hayward Single Speed 1-1/5 Hp Pump - 3/4 HP "Booster" (?) Polaris 280 Vacuum
    48 Sq Ft, 96 GPM, Diatomaceous Earth Filter
    Pool is approximately 15+ years old- Newer than 1985
    Hayward 300,000 BTU H300MV Heater (Milli-Volt UGH!!)
