Thread: Intex Ultra Frame through wall skimmer and main drains with plumb diagram
    Jul 2014
    Splendora
    5
    I just wanted to say thank you to this forum for helping me get our pool up and running great!
    First I want to say this being my first post I COULD NOT HAVE DONE THIS WITHOUT THIS FORUM!!!!!!!! the links and posts on here were perfect!
    52x22' ultra frame. We bought it from walmart a month ago. Got a decent deal on it for $599 This is actually our second ultraframe. First stayed up for a few years and was installed with all factory stuff, no mods but was past is prime.
    Here is a diagram of our layout with part numbers! basically two main drains cut into the bottom of the pool, jandy 3 way valve, Hayward trough wall skimmer, Hayward matrix pump, old Wateco sand filter (new sand and valve), Hayward inline chlorination(not installed yet) and the return that came with the skimmer. All piped in 1 1/2" pvc....well soon to be anyway.
    I will be piping in the chlorination and putting in a fountain and 3 way valve on the discharge side of the pump in the new future.
    Here is the setup minus the skimmer and while we were still piping it in. I was waiting for the skimmer in the mail. You can see the Jandy 3-way in this picture. we initally used the hoses just to get it up and going.
    first night
    Jul 2014
    Splendora
    5
    Re: Intex Ultra Frame through wall skimmer and main drains with plumb diagram
    Here are a couple more pictures
    Here are shots of the main drains.....
    One is dead center of the pool and the other is 9 feet away near the side. both have anti-entrapment covers and have a common suction line. This is the safe method of plumbing a drain. Since the skimmer and both drains come from ta common line, if you plug one up, all the suction shifts to the other two items eliminating any chance of entrapment. This absolutely awesome for sucking stuff from the bottom of the pool. The pool gets a rotating circulation which pushes every thing towards the center of the pool. The center drain sucks everything down. This eliminates about 80% of the debris in the bottom of the pool! The skimmer picks up the majority of the other stuff floating on top.
    Jul 2014
    Splendora
    5
    I wish I could have shown some progress pictures. anyway i just wanted to say thanks to everyone on the forum for sharing all of your information with all to use!
    Intex 22'x52" Ultra Frame
    Waterco Sand filter(not sure what model)
    Hayward Matrix 1HP Pump
    Modificationss-hayward main drains, through wall skimmer and PVC Piped. Mason sand base.
    Apr 2013
    Battle Creek, MI
    298
    My Chlorinator still sits in its box in the garage and I do all my sanitizing with liquid chlorine in the evenings.
    How difficult was it to install the floor drains?
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Jul 2014
    Splendora
    5
    The drains were pretty easy. They're a lot like a through the wall skimmer actually as far as install. you set them in place and pipe them over to the side. I taped the gasket in place. We set up the pool on top, added 6 inches of water....installed the inside gasket and ring then cut the hole. They're great because the circular current of water naturally pushes everything to the center and the drain just sucks it up. Been up and running for two weeks and there isn't a single piece of debris....we do scoop some stuff when we swim but for the most part it has worked great in my opinion.
    Until we get our chloranator in...I think we'll just use a floater
    May 2014
    mi
    27
    Love the floor drain. Wish I could do that mod but i think in the midwest I would have freezing problem with the pipes.
