Results 1 to 10 of 10
Thread: TA and pH
    TA and pH
    Hello. My pool was completed the first week of June. I knew I would have trouble keeping pH balanced and I was right. I have to add acid at least every other day. At first I had a TA of 120 and I worked to lower it. Now it is at 70, sometimes reads 60. Every other day or so my pH is at least 8.2. I add the acid at the appropriate amount and my pH stabilizes for the day. My question is do I need to raise the TA a little bit? Will that help keep my pH stable a little longer or is it only a high TA that affects pH rebounding? Or will I just have to accept the nearly daily battle with pH and acid?
    Other test results-
    FC- 5 first thing in the morning, (dosed with stenner overnight)
    Cya- 35 to 40
    CH- 350
    Did I miss something?
    Thanks in advance!
    Andrea
    35,000 gallon, IG pebble finish, cartridge filter, Pentair variable speed pump, Stenner chlorine pump, Dolphin Oasis Z5 cleaner, Spa, Slide and waterfall, construction complete June 1, 2014, TF-100 test kit, pool filled with Central Texas well water(very hard water)
    Jul 2014
    Prospect Heights, IL (NW Chicago)
    64
    Re: TA and pH
    The general rule is "If your PH is consistently high, then lower your TA. If your PH is consistently low, then raise your TA."
    Do you have a lot of sources of aeration that could be causing the PH increase? Any spillovers, fountains, waterfalls, etc?
    40x20 IG gunite (~36K gallon). 6' attached spa with spillover. AquaLink RS OneTouch + SpaLink + iAquaLink 2.0
    450 sqft Sta-Rite cartridge filter, Sta-Rite single speed pumps (main, spa jets, booster)
    Coverstar Auto Cover, Polaris 280 cleaner, Taylor K-2006
    Re: TA and pH
    Yes! Lots of sources of aeration. Waterfall, spillway, slide, bubblers in beach and kids, dog and other swimmers. I haven't noticed any connection to those considerations being out of the equation and a more stable pH though. How in the world does my TA stay so low? It isn't as susceptible to change I guess?
    Re: TA and pH
    PH increases come from paster curing and from high TA. If you raised TA, the reduced PH drift from plaster curing due to the higher TA would be more than canceled out by the increase PH drift from higher TA.
    Re: TA and pH
    Ha. Ok, Jason got it. I should do nothing then. Wait for plaster to finish doing what it's got to do I suppose?
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: TA and pH
    I just replied to another post about this. I had a new Pebble Sheen finish applied two months ago and went through 4.5 gallons of muriatic acid thus far. The first week taking a half gallon every other day with a TA around 110. I'm now down to only a 1/8 of a gallon every few days. I also have a slide that has water that aerates the pool some what.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Re: TA and pH
    I have a pebble finish as well. Filled pool first weekend of June. I've been through more acid than that (maybe 6 gallons?). At first my goal was to lower my TA so I added enough acid to get a pH of 7.2 and then my pool pal app said to aerate to get pH back to 7.6. I did that until my TA dropped so much. Now I'm in a daily battle to keep pH below 8.0. Frustrating and I hate handling that acid so often. Anyways, at least my bleach is automated! I'll keep hoping that things will level off a bit. Thanks for the advice y'all!
    Jun 2014
    The Woodlands, TX
    167
    Re: TA and pH
    Quote Originally Posted by alright_alright_alright View Post
    This is the same problem I am having and posted about in another thread. My pebble finish was also done in June. Could be still simply curing? Good to know.
    8,000 gallon in-ground gunnite geometric. Wet Edge Satin Matrix. Triple overflow water feature.
    Hayward - TCell 15 SWG; TriStar VS Main Pump; SwimClear 425 Cartridge Filter; ProLogic 4 Automation, SuperII Water Feature Pump; Polaris 280 w/ Booster
    Link to my Build
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: TA and pH
    The pebble tech guy told me most of the curing is done the first three months.
    Oct 2013
    Oklahoma
    50
    Re: TA and pH
    We finished our pebble tec finish in February and have the same problem as you. Maybe not quite as intense. Adding 16-32 oz per week of muriatic acid. Waterfall runs about an hour per day. TA near 60.
    13000 gallon pool, SWG, DE Filter, 2 sheer descent waterfalls, built Jan 2014
