Thread: How to manage CSI; and calcium hardness increasing
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Hi all. I've been TFP for three years now so nothing goes in my pool except what I know. I have two questions:
    1) When I first started testing my pool in summer 2011 my CH was 170 and I raised it to 300. It's stayed around 300 (plus or minus 30) these last 3 years. Last test was 6/25/14 at CH320. Today I tested 7/21/14 and it is 400! I did the test twice. I tested my tap water and it's less than 100. Since 6/25/14 I have added MA and CYA only. I have a new salt cell so have been running on the higher side of FC (around 9-10) as I adjust my salt cell run time and % to get to an ideal of around 8. So what is making my CH rise? I know what I need to do to lower it (25% drain), but what is causing the climb? Before I drain I'll wait a few days and test again.
    2) I have calcium scale, identified by calcium deposits on the bottom and sides of the pool. I attribute this to me not paying attention to PH frequently enough during the winter . The sides I can readily clean with a stone thing (don't remember at the moment what it's called) but I can't hold my breath long enough to do the bottom. So I've been trying to manage CSI in an attempt to naturally reabsorb the calcium. BUT, I can't find any reasonable combination of chemical balance in PoolMath to get my CSI closer to zero. I usually run around -.4 to -.5. What do I need to balance to drive my CSI closer to neutral, and is this what I should be doing? The CSI for the SWG/plaster preset "goal" is -.56, so I'm not sure if that should be my goal rather than 0.
    Today's readings:
    Water temp: 83 (was in the 90's the last couple weeks)
    Salinity: 3.1
    FC: 10
    CC: .5
    TC: 10.5
    PH: 7.4
    TA: 60 (dropped from 70 after MA addition so I'm just letting it ride and watching)
    CH: 400
    CYA: 65
    Borates: 60
    CSI: -.5
    Thanks for your help!
    Sandra
    18,000 gallon freeform inground plaster
    Jandy 1.5 hp pump & .75 hp booster pump
    Aquapure SWG
    Pentair Triton II sand filter
    Legend pressure-side vacuum
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Re: How to manage CSI; and calcium hardness increasing
    Gratuitous pictures
    Calcium spot:
    & long shot of calcium spot showing water clarity and sparkliness where not in the shade. The vacuum is 6.5 feet down.
    Thanks!
    Aquapure SWG
    CSI in the -0.4 to -0.5 range is fine for day to day balancing. I would raise the PH a little from what you have for normal use, say to 7.7, but that isn't critical or anything.
    If you want to remove calcium scale by lowering CSI, which I don't really recommend, you would need to get CSI down below -1, and keep it there for a while. Doing that is called a no drain acid wash, and removes plaster from the pool surface as well as removing the scale. It also often takes months.
