Thread: Baby fence posts on travertine decking??
    Mar 2014
    Tampa
    103
    So I called my PB's baby fence barrier company to add a self closing gate. He asked me what type of decking-travertine. He mentioned to properly secure the posts they should have a footer poured every 36" for the posts under the travertine if it's layed on concrete base and sand. The decking is not laid yet.
    Has anyone with travertine decking with baby fence had this issue and if so, what did the PB and/or Fence company do as options?
    I was thinking when they drill into the 1 1/4" of travertine paver, can they extend a long sleeve into the dirt and pour concrete into that?
    Just a thought..
    thanks!
    Sep 2013
    Nashville, TN
    382
    Re: Baby fence posts on travertine decking??
    Since the deck isn't down yet I would have the footings poured first, you would not be able to get enough concrete in with such a small hole drilled later
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
