PH Vs CSI
mmdhar
59
Chandler, AZ
Which is worse? PH of 7.0 or CSI of .36?
If I increase PH to 7.5, my csi will be .36. If I leave PH 7.0, my CSI is -0.11 closer to zero than .36. But, leaving PH at 7.0 is ok? Which is better?
Other numbers:
FC - 7
TA - 80
CH-625
CYA -60
Temps - high 107 (AZ)
Thanks!
With a CH that high, you are probably better off slightly negative than positive and you really don't need to worry much about CSI between -.5 and .5.
