Thread: PH Vs CSI
    Jul 2013
    Chandler, AZ
    43
    PH Vs CSI
    Which is worse? PH of 7.0 or CSI of .36?
    If I increase PH to 7.5, my csi will be .36. If I leave PH 7.0, my CSI is -0.11 closer to zero than .36. But, leaving PH at 7.0 is ok? Which is better?
    Other numbers:
    FC - 7
    TA - 80
    CH-625
    CYA -60
    Temps - high 107 (AZ)
    Thanks!
    12x40 In ground, 16K Gallons, Pentair VS pump, 420 catridge filter, 140HC Heatpump, Stonescapes pebtec surface, Chandler, Arizona
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: PH Vs CSI
    With a CH that high, you are probably better off slightly negative than positive and you really don't need to worry much about CSI between -.5 and .5.
    Mark
    Jul 2013
    Chandler, AZ
    43
    Re: PH Vs CSI
    Thank you! Just to be clear there is no downside for having PH at 7.0?
    Re: PH Vs CSI
    Many people find that their eyes sting a little when swimming underwater with the PH below 7.2. We don't normally recommend going below 7.2 for that reason, but otherwise, 7.0 is alright.
    Jul 2013
    Chandler, AZ
    43
    Re: PH Vs CSI
    Thanks Jason!
    Re: PH Vs CSI
    I'm not seeing how your CSI is that high. What is your water temperature and what is your salt level?
    How are you chlorinating?
    Support the site
