Results 1 to 10 of 10
Thread: New heater. System pressure is now much higher.
    EvilTwin's Avatar
    May 2014
    Phila. PA
    45
    I had a new Pentair 300k btu propane heater installed today to replace the 20-year old oil fired unit that was here when we bought the house. I have not been able to heat the pool with it yet as I am waiting on the gas bottle hookup. But the one thing I immediately noticed was that the pressure gauge on my DE filter is now showing 20 psi whereas with the previous heater the normal pressure was around 12-14 PSI. This kinda surprised me and makes me think that the system is now more constricted than it was before, even though the plumbing has been simplified in the process. He did add a new check valve as well. Is this jump in PSI something to be expected? Is 20 PSI good/bad? I have attached before and after pics for reference.IMG_0147.jpgIMG_0246_sm.jpg
    25000 (?) gallon Plaster IG roman-end pool (18x36, give or take, 8 ft deep end), 7 ft round spa-spillover to pool
    Nautilis FNS-48 DE Filter, disconnected separation tank
    1.5HP single speed main pump. 3/4 HP pressure-side cleaner pump.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: New heater. System pressure is now much higher.
    When I connected my heat pump there was a pressure increase of 4 to 5 psi. I had the same concerns as you, but the experts on this forum assured me that a 4 to 5 psi increase was perfectly normal. I don't know how similar the internals are between a pump and a gas heater, but I imagine some increase in pressure for you would be normal.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    mas985's Avatar
    Pleasanton, CA
    11,737
    Adding a heater will usually raise PSI but replacing one should be about the same. But from the picture it looks like you had a heater bypass but no longer do so that would explain the difference.
    Mark
    EvilTwin's Avatar
    May 2014
    Phila. PA
    45
    Quote Originally Posted by mas985 View Post
    Yes, that is true. There was a heater bypass in the plumbing but they left that out when they put in the new plumbing. The installer said it wasn't necessary. I reviewed the heater manual and it recommends a bypass if the flow rate exceeds 120GPM. I have a 1.5 HP single speed pump. Not sure if it would exceed that flow rate.
    mas985's Avatar
    Pleasanton, CA
    11,737
    No it isn't necessary although it does lower the head loss and pressure.
    Mark
    You are fine on flow rate, a 1.5 HP pump is never going to exceed 120 GPM.
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    I've seen more of a pressure change only with certain brands of heaters. Strange. A bypass also comes into play if you should need to do a stain treatment or similar. You surely don't want that going thru the heat exchanger.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    mas985's Avatar
    Pleasanton, CA
    11,737
    Some heaters have a built in bypass while others don't which can make a big difference in head loss.
    Mark
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Actually they all have built in bypasses aka flow control.
    Paul
    mas985's Avatar
    Pleasanton, CA
    11,737
    Maybe now all do but I have seen some off brands and older heaters that do not have the bypass.
    Mark
