Results 1 to 10 of 10
Thread: First Time Vinyl Pool Opening FC/CYA Questions
    Jul 2014
    Macomb, MI
    18
    Hello,
    First time opening my pool. I'm just starting to add CYA with a sock in fron tof my return line and had two quick questions. First, is it safe to swim while CYA is being added as long as I tell everyone to stay away from the sock? Second, my pool installer added quite a bit of bleach when they were adding water so right now my FC level is between 5 and 7 (with no CYA), safe to swim at this level? I know it will burn off today since it is super sunny, but of course everyoen wants to use the pool now!
    Thanks for your responses.
    14k gal, AG, 1hp waterway, sand, heat pump, 7/16/2014 install
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    Re: First Time Vinyl Pool Opening FC/CYA Questions
    I would be swimming! You should be safe to swim until you're over shock level.
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
    Jul 2014
    Macomb, MI
    18
    Isn't 7 over shock at 0 CYA??
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Shock level for 0 CYA is 10. 😎
    Jeff
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    Well I guess it depends on the other criteria, do you have CC over 0.5? What does the water look like? If clear water and CC <0.5 I would swim in a chlorine level of 10 with no CYA....but that is me......my opinion.
    Jul 2014
    Macomb, MI
    18
    haven't done the CC test yet, but the water is super clear so I imagine I am good (just filled it two days ago).
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    Yeah, fresh fill should be good to go. I was just assuming all other criteria was met, and it is never good advice to tell other people it is safe to swim. There may always be other factors involved. What you've given me for info, would have me swimming in my pool. I would think the water would still be cold, but hey, you MI people are tough!
    Oh, just seen you got heat pump...
    Jul 2014
    Macomb, MI
    18
    I installed a heat pump so I'm already at 82 degrees
    Jul 2011
    Perrysburg, OH
    88
    Nice, I'd be swimming! Just keep an eye on pH as it will go down as you add CYA.
    16 x 32 inground vinyl pool (21000 gallons) (new liner installed 2014)
    Hayward max flo pump w/ 1 HP AO Smith motor (new motor 2014)
    Hayward C1200 cartridge filter (new 2014)
    Hayward H150 heater
    Oct 2013
    Chapin, SC
    1,141
    Whenever I add Stabilizer to my pool, I squeeze the sock every 15-30 minutes and have yet to see any affect on my hands. I'd go swimming! That said, what I AM very careful of is to avoid inhaling any of the powder dust while pouring it into the sock.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
