Thread: Electric pool heater? Pahlen
    In search for NG heater or heat pump for 27' AGP and I came across a company named Pahlen, swedish company, that sells electric pool heaters. Very interesting reading and I was wondering if anyone has been able to try one.
    http://www.pahlen.com/our-products/h...ers/index.html
    They do have North American distributors.
    Thanks for any input.
    27' Aqua Leader Reflexion AG, 54" high, 5 FAFCO solars,
    Zodiac Clearwater SWG, Hayward 2-spd pump
    Hayward ProSeries filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Electric pool heater? Pahlen
    Electrical resistance heating is about the most expensive way to heat anything. A heat pump gives you several times as much heat per KW used as a straight resistance heater.
    Jul 2014
    Macomb, MI
    18
    Just turned on my heat pump yesterday. Went from 68 to 81 in less than 12 hours and ambient temperature was less than 76 degrees (high humidity). So I glad I went that route!
    14k gal, AG, 1hp waterway, sand, heat pump, 7/16/2014 install
    Jul 2014
    Oakbank, Canada
    389
    Depends on the cost of your electricity, varies quite a bit across North America. Here in Manitoba, Canada, its quite cheap.
    Quote Originally Posted by JohnT View Post
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    SW Indiana
    9,199
    Quote Originally Posted by DarrelB View Post
    A heat pump still produces around four times the heat for the same power use as resistance heating.
