Thread: Lowering my TA
    Otis Campbell's Avatar
    Mar 2013
    Lewisville, TX
    78
    Lowering my TA
    I had a pool fill snafu and my pool got filled to the brim. I must have made a mistake when I was tinkering with my sprinker system controller and the zone for the pool fill ran about an hour and half overnight.
    So my chemicals got out of whack. Here are the readings I took yesterday afternoon. FC 1.4 CYA 70 PH 7.0 TA 160. I was happy to see my CYA at 70 as I had put a lot of effort into getting that up to where it needed to be.
    I added some 10% chlorine per the pool math page to get the FC up. I need to get my TA down, obviously. I've been reading about aerating. I've got blowers on my spa. Should I just turn those on and let them churn to perform the aeration?
    Thanks.
    Inground Gunite, plaster surface. 28,000 gallons, modified L shape with diving area and play area, attached spa. All Pentair equipment including SWG, EasyTouch automation, variable speed pump, DE Filter, Nature 2 Express. Taylor 2006 test kit.
    Why should you become a Lifetime Supporter of TFP? Because the first time you have a problem and you get the solution at TFP you will recoup your cost many times over.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Lowering my TA
    Quote Originally Posted by Otis Campbell View Post
    Thanks.
    That's what I did. Full return through the spa, maximum aeration by every means possible.
