Results 1 to 12 of 12
Thread: Chemistry is my worst subject
    Jul 2014
    Phoenix, Arizona
    16
    Good morning all...
    I know you all get this a bazillion times but seeing this is just getting started please go easy.
    Was gone for the weekend and my family isn't good with pool matters.
    last night my FC was <5 and my pH was 7.5
    According to the calculator I need to add chlorine, so I added a gallon last night.
    FC is off the charts like a SLAM
    and
    pH is >8.5
    CYA is 70
    Calculator calls for acid...?
    CYA says replace 57% of my water? Not happening I just refilled the pool last weekend!?!?!?!
    WTH!!!!
    Help me please...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Chemistry is my worst subject
    The pH test is invalid if FC is above 10. It reacts with the red drops and makes it read falsely high. That's precisely why we suggest adjusting the pH before the SLAM, and then ignore it until FC drops again at the end. So don't add acid until FC drops and you can get a valid pH reading.
    Why did you add so much bleach?
    Oct 2013
    Chapin, SC
    1,141
    Off the charts is not an adequate description of your FC level. Without a full set of test results, and how they were determined it's almost impossible to help you, but yes, your ph may or may not need acid to get it down. A gal of 8.25% should only raise your FC by 4 ppm.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jul 2014
    Phoenix, Arizona
    16
    >5 the scale goes to 5 and stops. Last night it was <.5
    I added liquid chlorine because that was what the calculator called for last evening...
    I wasn't intended to slam it.
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by timerguy View Post
    Off the charts is not an adequate description of your FC level. Without a full set of test results, and how they were determined it's almost impossible to help you, but yes, your ph needs acid to get it down.
    I disagree. His pH was 7.5 before overloading with bleach. The pH test results are suspect at best, and almost certainly wrong. Check the pictures and captions in this thread:
    http://www.troublefreepool.com/threa...els-with-R-007
    Oct 2013
    Chapin, SC
    1,141
    I edited my post, but the point was there's insufficient detail in his test results to give him definitive help. More glaring is there's no cya test. He has a swg so he might not have that running properly either. No telling what his goal is for FC.
    Last edited by timerguy; 07-21-2014 at 09:25 AM. Reason: I hate this tablet keyboard
    Jul 2014
    Phoenix, Arizona
    16
    CYA is posted... 70
    CWG is "NOT" running as of yet, 2 more weeks till Pebble Tec cures and the start it up...
    Would like my FC 3-4 not sure yet, just learning, thus the post. "Chemistry is my worst subject."
    Those pics help.
    FC is Bright >>>BRIGHT<<< YELLOW not orange
    and the pH is a brighter than 8.2.
    @ TFP EXPERT - so FC should be referred to as bleach...?
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by HotAZPool1 View Post
    CYA is posted... 70
    Those pics help.
    You're running into the problem with most test kits - they can't measure free chlorine at the levels you need. Remember, for now, yours is a bleach pool, so FC needs to be at minimum 5. http://www.troublefreepool.com/conte...art-slam-shock Your tester maxes out at 5, so you're working blind above that. Bright tweety-bird yellow is about 10, but it could be 7, it could be 14. You just don't know... Adding the FAS-DPD test will close that gap. http://tftestkits.net/FAS-DPD-Chlori...-test-p47.html
    FC is not necessarily bleach. When your SWG is running, FC will be generated right inside the cell. It can also come from trichlor or dichlor or Cal-hypo, or Lithium hypochlorite. Bleach just has the fewest unwelcome byproducts. And before you ask - no, there are no powdered chlorine products that don't add something else. More detail here:
    http://www.troublefreepool.com/conte...nate-your-pool
    Bottom line, the FC level will drop with time and sunlight, and your pH test should start reading correctly later today.
    Jul 2014
    Phoenix, Arizona
    16
    @ Richard - thanks. I had I feeling the FC/Bleach would burn off. But the pH clarification was what I needed. I just didn't want to throw the water chemistry completely out of whack.
    Jul 2014
    Phoenix, Arizona
    16
    Is the K-2006 the best(reasonable) kit to purchase?
    Thanks for all the help...
    Dennis
    Richard320's Avatar
    Jan 2010
    19,075
    Dennis
    If it's not too late, the TF100 is actually a better deal. The quantities are more realistic. Check out Test Kits Compared.
    Jul 2014
    Phoenix, Arizona
    16
    @Richard - nope not too late. I will take your advice.
    Also the chemistry is back to normal this morning,
    FC 5
    pH 7.5
    CYA 40
