Results 1 to 9 of 9
Thread: PH Bounce
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    PH Bounce
    Here are my numbers
    FC 6.5
    CC 0
    PH 7.8
    TA 75
    CH 325
    CYA 75
    Salt 3300
    I try to keep the PH at 7.6, but it seems I have to keep adding MA to keep it down, is that normal, I have never let it go over 8.0....Thanks for a sparkling pool...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: PH Bounce
    That's very normal with a SWG. Try lowering pH to 7.4 and stretch the acid interval a little.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: PH Bounce
    Thanks Richard... Will do
    Autopilot SWG
    Re: PH Bounce
    As your TA comes down, the time between acid additions should get longer. Eventually the PH may be stable at 7.8.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: PH Bounce
    TA is at 75 I don't want to go much lower, or is that not a problem? Thanks Jason
    Autopilot SWG
    Richard320's Avatar
    Jan 2010
    19,051
    Re: PH Bounce
    Quote Originally Posted by boston62 View Post
    Sent from my SCH-I535 using Tapatalk
    You can go lower with no problem. Check out http://www.troublefreepool.com/conte...rine-generator
    Re: PH Bounce
    TA down to 60 is just fine. I wouldn't go below there unless you are also using borates.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: PH Bounce
    Will bring it down to 7.4 and stretch adding MA....Thanks Everyone....
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: PH Bounce
    I brought the PH down to 7.4, had to go away for 2 days, when I came back these were my numbers.
    FC 5 down from 6. PH 7.6 up from 7.4 CYA 60 down from 75
    I did add 6 vitamin c tablets on some stains to remove them, which they did.
    Should i adjust? Thanks
    I just tested my CYA with the pump running for 2 hours and its back to 75 where I wanted it...
    Autopilot SWG
