Results 1 to 8 of 8
Thread: salt how much should I add?
    I have noticed that my eyes sting a little bit when I'm in my pool. I read here that your eyes have a certain amount of salt. And if your pool is not the same as your eyes it can sting. So I added one 40lb bag. It seemed to help a little. Could I add more? Thanks. Filix.
    18k IG 16'x32' vinyl liner Haywood S-200 high rate sand filter pump Haywood Encl.3 1hp A.O.Smith Corp
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: salt how much should I add?
    What are your test results?
    More likely is a way high or low pH. Normal pH for tears/eye fluids is 7.4-7.6. If your pool deviates too far from that, you will get that stinging.
    pH is around 7.4 Total alk is 80, no cc, fc is 4 ppm cy is 40 ppm Pool temp is 87
    May 2009
    Marion, Ohio
    32
    We have a 10,000 gal Inground vinyl and I added 5 40 lb bags of solar salt in June. It feels great!n
    10,000 gallon inground vinyl FOXX pool - built in 1999. Hayward sand filter. 3/4 HP 2-speed pump with timer. Hayward Aquarite SWG t-3 cell. Love the BBB method - pool has never looked better!
    Thanks people for your help. I think I will add more. filix
    38,539
    Why not measure your current salt level and use PoolMath to tell you how much to add to reach your target?
    For a non-SWG pool, seems that 2000ppm is typical.
    How should I measure salt? Thanks. filix
    38,539
    With a salt test. Or have the pool store do it.
