Thread: New Pool just filled & added chemicals NOW tint of green!!! Help Please!
    Jul 2014
    toms river new jersey
    4
    Hi, Just finished filling pool with city water yesterday & completed the required tests for BBB method results were at 11:00am:
    FC 0
    PH 7.0
    TA 30
    CH 30
    CYA 0
    B 0
    Put all the figures into pool math and added exactly the given amounts.
    At 7:30pm tested pool again and the results were:
    FC 5
    PH 7.2
    TA 80
    CH 30
    CYA 60
    B 10
    Just went out this morning 5:30am to check and the pool is clear to bottom but with a shade of green
    tested again and the results are:
    FC 5
    TC 5
    CC 0
    B 10
    PH 7.2
    TA 80
    CYA 90
    Please help I'm a newbie and not sure what to do next. ty you for any help given to this matter
    Intex AG Vinyl 18x48, 6,423 gal, Intex 28651 Sand filter, 3200 gph, Install 7/2014, Taylor K-2005 test kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New Pool just filled & added chemicals NOW tint of green!!! Help Please!
    What test kit are you using?
    Did you add liquid CYA?
    Have you seen the youtube video on the CYA test? Link in my sig.
    Welcome to TFP
    You're done SLAMing when:
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    You just started the pool, so we need to know exactly what you have put into it to date. I'm surprised at the CYA numbers going up that fast and wonder how much you put in.
    The K-2005 test kit in your signature is limited to 5ppm chlorine. You really should pick up a FAS/DPD Chlorine & CC's test to increase your limit up to 50 for free chlorine and test for combined chloramines. Both of these are required if you are going to follow the TFP methods.
    I'm going to guess you have something growing in the pool, but without complete testing it is impossible to know for sure. We do not "shock" our pools, we follow the SLAM Process when there is a problem.
    Try to order the test kit addition today if possible and keep the chlorine up until it gets in.
    Support the site
    Jul 2014
    4
    thank you, I just ordered the test kit & I will keep the chlorine up until it gets here. thank you again.
    Butterfly's Avatar
    South Carolina
    10,045
    Has the green tint gone away? It sounds like metals in the fill water. A sequestrant should clear that up.
    What have you added to the pool?
