Thread: Help what to do with leak on the top of the wall?
    Jul 2014
    Fresno, California
    26
    Oh boy so it's almost midnight here. My pool is almost filled to the rim. I was about to dump some salt in, run the pump and let it go overnight....and what do I find a freaking leak. What do you guys think I should do? Theres none on the liner that I can see it's on the wall it looks like it might have been torn when connecting the poles together but after double checking the poles aren't even near it. Smh. There's some patches included but they say it's gotta be dry. There's no way I can get away with patching as is right? Something temporary maybe duct tape?
    Its nearly full if I just shut the water off and leave what's in there as is and start working on it tomorrow will I be fine (without putting salt in or the pump on)? I don't want it to go green on me. I guess I should stop filling it tomorrow drain, them patch, hopefully it's not a mess by the time I wake up I need some sleep. It's a shame because the thing is darn level and I thought all would be well. See if I can even sleep.
    Edit: btw the hole isn't pouring out water as bad as it looks. I'm kind of thinking of running the pump and dumping salt in anyway then fixing first thing in the morning, after seeing this water compliant glue and patch here: https://m.youtube.com/watch?v=YuOi76aUWMQ
    Casey's Avatar
    SW PA
    10,438
    Re: Help what to do with leak on the top of the wall?
    Welcome to TFP!
    Can you please finish filling out your signature with your pool specs so we can help you with this issue and any future issues?
    What we need to know to answer your questions
    Did you end up fixing this or do you still need help?
