Thread: Deer on the winter cover.
    Jun 2008
    Thornton, PA
    76
    Folks-
    Been taking bids for a winter cover -come to find out they're not cheap....
    Side point, My inclination is to go with a solid Anchor cover -seems to the best except for being heavy and requires a pump...
    But anyway, I'd like to protect my investment, and am thinking that one real risk is deer. There's no real 'food' inside the fence of my pool area except grass, and there's plenty of that outside the fence, nor does the fence obstruct thier movement, but I'm still concerned....
    Is there a particular color I can get to detract deer, or something I could do to keep the buggers off the cover?
    Is there a type of cover that will better defend against/ prevent/ withstand deer walking on it?
    If what I purchase can have an impact on any of this, I'd like to know now before I actually spend any mony -seems to me...
    Thoughts?
    Dan
    28K Gal. 802 Sq Ft., Free Form, IG, Gunnite with Midnight Maui Hydrazzo Carlton Pool. Exposed Aggregate Decking. Jandy DE Filter, 1.5 HP Jandy Pump, SWCG. Zodiac 380 pressure-side cleaner. Completed Construction: May 2008.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Deer on the winter cover.
    You can get a Loop-Loc mesh cover that will not require a pump and will easily tolerate a deer walking on it (as will any Loop-Loc). Loop-Loc also makes a solid cover with a mesh drain in it which doesn't need a pump.
    Baton Rouge, LA
    237
    30-06?
    18,000 gallon gunite free form, with spa, 4x160, EasyTouch, SWCG, Pentair cartr filter, Colorlogic lights.
    Jul 2007
    Suwanee, GA
    528
    Quote Originally Posted by stevenbrla
    30-06?
    That would do it for sure. Or invite the ivyleager over.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
