Thread: How do I remove the lightbulb from my pool light?
    S1ngram's Avatar
    Jun 2014
    Chrisman, Illinois (East Central Illinois)
    304
    Question How do I remove the lightbulb from my pool light?
    I'm working on a slam at the moment. I have an aqualuminator return/light. I want to remove the bulb to see if anything is growing behind it. I can't figure out how to remove the bulb and I sure don't want to break it. Ideas and instructions will be greatly appreciated.
    27' round Seaspray Evolution, AG, 17,100 gallons, Pump: Hayward Power-Flo Matrix Dual Speed 1.5 hp, Filter: Hayward Pro Series High Rate Sand Filter, June 18, 2014, Kreepy Krauley Lil Shark, TF-100 test kit, Intex Krystal Clear Saltwater System
    Casey's Avatar
    SW PA
    10,446
    Re: How do I remove the lightbulb from my pool light?
    Welcome to TFP.
    I'm not sure you can easily take the bulb out of the aqualuminator. I did a quick search using the search box at the top right under pool school and came up with this.
    Fix Your Aqualuminator Once and For All!!! (((Use at your own risk)))
    If there is no water in the light, I would not mess with it but that's me. Good Luck.
    S1ngram's Avatar
    Jun 2014
    304
    Thanks for reply. I ended up removing the light from it's housing just to see if there was anything behind the light. Nothing was there and now I know how to replace the light with the water in the pool.
