Thread: Orange Water after shocking
    Jul 2014
    Aurora,
    1
    I just purchased an AG pool. Installed it as instructed including filter and such. We then again as instructed filled the pool and shocked it and we now have orange water. The water is well water that is quite high in iron. How can I fix the problem. I would like to use the BBB system. The Pool is 10000 gallons according to your pool math.
    Thank you,
    santaelf
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Orange Water after shocking
    You'll need to add a sequestrant regularly. From the Pool School article on metals in the water:
    "Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective. ProTeam's Metal Magic and Jack's Magic The Pink Stuff (regular), The Blue Stuff (fresh plaster), and The Purple Stuff (salt) are some of the top sequestrants. You can also find many other brands with similar active ingredients, some of which are noticeably less expensive."
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to the forum Santaelf
    Please add your pool info into your signature as outlined here - - > http://www.troublefreepool.com/conte...etting-started
    You might want to consider using one or two of these next time you fill the pool and when you need to add water. http://www.amazon.com/Pre-Fresh-Gard.../dp/B00AXP8B9O
    I have well water and I don't have a problem with it in the pool but I do in the spa due to the heat. They do work well. Best to shop around on price they can vary quite a bit depending on where you buy them.
    Solar Blanket, Well Water, Borax Added. 76
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Orange rust is good! It can be filtered out! Scroll down to post 14 in this thread: http://www.troublefreepool.com/threa...ly-Rusty-Water
    Post 23 here: http://www.troublefreepool.com/threa...ll-water/page2
    Once you get most of that out of the water completely, the sequestrant will keep it in suspension. Sequestrants work like the candy shell on M&Ms - the chocolate is still there, but you don't see it.
