Thread: Pool accidentally draining! how do I shut off the main drain??
    futility's Avatar
    Jun 2014
    Pacific NW
    11
    suddenly it's draining!
    Got clear enough to see bottom and enjoy.
    Main drain cover was broken, bunch of bricks/rocks in there. I pried one out with a pole and a few hours later I've lost 6" of water. could the rocks have been holding a plug in? I don;t know how to stop it. Pool is from 19878. drain looks like a skimmer basket, can;t make out what is down there. are they designed to be operated from above with a pole? so I have to swim down to turn it off? can I put a rubber welcome mat over it to stop the flow until I figure it out? would be a shame to lose all the water I just spent a month cleaning!!!
    22000 gal / IG / plaster / Hayward S244T - 3.1 sq' - 62 GPM / 1 speed pump / 1978 / gas heat (inactive)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool accidentally draining! how do I shut off the main drain??
    The drain is normally connected to the pool plumbing. Usually the plumbing connects from the side and there is a hydrostatic relief valve in the bottom for gunite pools.
    Most likely the hydrostatic relief valve is stuck open.
    Support the site
    futility's Avatar
    Jun 2014
    Pacific NW
    11
    Quote Originally Posted by JamesW View Post
    Thanks! I think that's what it was. A couple of trips down with goggles revealed a large threaded plug. A couple of more 'dives' and I had it screwed back in and haven;t lost any more water. Adding enough to reach the skimmers so I can run the pump again!
    Jul 2014
    Clermont Florida
    56
    This happened to me before, cleaned the filter and didnt put top on perfectly right(it can be a pain). Went outside 30 minutes later and i see half my pool water gone
