Results 1 to 11 of 11
Thread: Quick Update and Reassurance to test results
    May 2011
    Orlando, Fl
    36
    Hey guys just wanted to post my results from the TF 100:
    FC 7
    CC .5
    TC 7.5
    PH 7.8
    TA 190
    CYA 50
    The only thing i noticed is on the small Chlorine and Ph tester it says 1-2 which doesn't coincide with the other results.
    Anyways how does everything look?
    20K gal Cartridge Filter IG Pool Plaster 1hp pump
    Re: Quick Update and Reassurance to test results
    Overall that looks good. Your TA is a bit high. I recommend lowering PH to 7.2 each time it gets to 7.8 until the TA comes down some.
    May 2011
    Orlando, Fl
    36
    thanks Jason.. i was wondering if anyone could explain the difference between the two tests?
    The OTO chlorine test (drops turn the sample some shade of yellow) is quick and easy but only measures TC up to 5 and it is very difficult to distinguish levels between 3 and 5. This test excels at a quick chlorine or no chlorine check.
    The FAS-DPD chlorine test (powder turns the sample pink, drops turn it back clear) is slower but measures both FC and CC from 0 to 50 in steps of 0.5. This test is the one to use for knowing exactly what your levels are. However it can very rarely report no chlorine when chlorine is actually very very high.
    May 2011
    Orlando, Fl
    36
    thanks for your answer!
    May 2011
    Orlando, Fl
    36
    So i tested again today and my CYA is 49 but my FC is 0
    TA is 150
    PH is between 7.6 and 7.8
    Is that fast? I hadn't put anything in since Sunday should it lose that much FC in 3 days?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Your pool probably loses between 2-3 ppm per day. So that's not fast. You have to add chlorine everyday. I would add some bleach ASAP or your heading towards algae. 😎
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    You have to feed it everyday...
    May 2011
    Orlando, Fl
    36
    ahh ok! if i have a 2.5 gallon jug how much you think i should add each day?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    For your CYA level of 50 you need to maintain your FC level between 4-8 and never below 4. Target 8.
    Use Pool Math to figure how much bleach to add to reach your target of 8.
    How much you have to add each day depends on how much FC you lose each day. Testing FC will tell you how much you lose each day.😎
    Jeff
    Richard320's Avatar
    Jan 2010
    19,051
    Quote Originally Posted by Natesroom View Post
    That's what testing will tell you. In a couple weeks, you'll have a good idea how thirsty the pool is, but in the meantime, test, plug it into poolmath, and dose.
    Good instructions for using poolmath and setting up the suggested levels and the bleach strength are in this article: http://www.troublefreepool.com/conte...ool-calculator
    If you're at zero now, and you target 8 and your pool is 20,000 gallons and the bleach is 10%, you'll need 1.5 gallons. If the bleach is weaker or stronger, that quantity will be different.
