Thread: Best times to test?
    Jun 2008
    Georgia
    22
    Best times to test?
    Hi everyone. We've had our pool for a couple weeks now and it has been sparkling clear and wonderful, thanks to all the great info here and the BBB method.
    Just a couple quick questions though:
    When we swim in the pool, is there a minimum time that should pass before I test the water?
    Also, when is the optimum time to test in general? Morning and evening I assume due to less sunlight.
    I've been testing in the evening, anywhere from 6pm-8pm.
    Thanks for the help.
    Doughboy 16' x 24' AGP, 9200g, Hayward 1 1/2 HP pump and Sand Filter. Sparkling water due to BBB method.
    Leisure Time Spa, Salida G-3, 275g. Also clear and clean due to BBB.
    Re: Best times to test?
    Test for chlorine in the evening. Then you can add your daily bleach so it can work overnight!
    For all the other tests, time of day is not crucial, but you might as well do any others at the same time as the FC!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I test ours in the evening just as the sun is setting providing no one is in the water. If there is I usually just scoop out a sample and test it then add the required chemicals after everyone has been tossed out !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Casey's Avatar
    SW PA
    10,461
    I test in the evening too!
