Results 1 to 16 of 16
Thread: Deck-O-Joint failing on patio and coping-tile joint
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Hey all,
    My Deck-o-**** on my patio and a similar product between the concrete coping and waterline tile is failing (see pics) and I need some advice on how to repair it.
    Patio flat sections:
    I have seen here where Sikaflex sl (self leveling) is recommended. Obviously this is only for more or less horizontal surfaces. How runny is this stuff? The concrete is graded toward the middle and down to a drain. Is it thick enough that it only flows to level locally and wont all run to the center?
    My thought here is to use a multi-tool to remove what I can, clean out as much as possible, use backer rod for deep areas and then Sikaflex Sl. Anything more to it than that?
    Vertical coping-tile joint:
    What do I use here? Is there a recommended Sikiflex product that can be applied to vertical surfaces? Any advice here is welcome.
    Bull nose end section:
    These are all in pretty good shape so I will probably leave them in place. If I did want to replace these is it even possible (and have it look good)?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Deck-O-Joint failing on patio and coping-tile joint
    Nobody has any thoughts on this?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    I used sikaflex on my deck. I have a 1 inch slope per 4 ft. The sikaflex does flow a bit down hill just a bit but no so much that a normally sloped deck would be problematic. You would do good to fill the joint about 3/4 way, and then go back over it again the next day to finish it off after round 1 has set up. Thats what I did.
    If you have a joint that falls off the edge of the deck, you will need to put a piece of duct tape or gorilla tape on it to make a dam so the sikaflex doesnt run out of the joint and onto the ground.
    As wide as your joints are, you will need to put foam backer rod into them so you dont need so much caulk.
    I dont know of a product for the vertical surface over the coping. The sikaflex I used wouldnt work for that part of it.
    Thats about as much info as I can offer
    Divin Dave,
    38,475
    Usually a polyurethane caulk is used between the tile and coping. I can not remember the name of the products though ...
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Is it MasterSeal NP 1 Sealant (Formerly Sonolastic NP 1)?
    38,475
    No. One is DECK-O-SEAL ONE STEP ... but there may be better alternatives.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    For the vertical coping application I have seen people mention:
    • MasterSeal NP 1 (Formerly Sonolastic NP 1)
    • Sikaflex 1a
    • Vulkem 911
    • Vulkem 116
    • Deck-O-Seal One Step
    Any inputs on these as to best for this application, easiest to use, longest lasting, cheapest, etc? Any others?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    So after a bunch more research I ordered MasterSeal NP-1 for the pool coping/tile joint and Vulkem 45 SSL for the concrete expansion joints.
    I also ordered backer rod and Scotch 2060 masking tape for hard-to-stick surfaces.
    I will post updates one I start the project.
    May 2011
    Los Angeles, CA
    228
    Please update us when you start the project. Iam in a similar situation with the coping to deck joint in need of a lot of caulking.
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I did the first chunk of the coping/tile gap yesterday. Picture is of one of the wider gaps. I am pretty happy with the way it came out. It took a lot longer to prep than I thought (backer rod and masking) although I think it will go faster now that I have the hang if it. I eventually gave up in using backer rod on the narrowest gaps (1/8" or less) as it was impossible to get it in.
    May 2011
    Los Angeles, CA
    228
    Which product did you use?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    As I said a few posts ago I used MasterSeal NP-1 for the pool coping/tile joint.
    I got Vulkem 45 SSL for the expansion joints but haven't started that part of the project yet.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Finished up the project. Here are some pics of the expansion joint fix.
    First used a chisel to finish breaking off the top layer which was about 50% destroyed by the Sun:
    Then used a multimax tool to remove the sides, and then cleaned well with a wire brush:
    Used bond-breaker tape on the bottom to avoid three sided adhesion, filled any wide gaps with backer rod, and masked the ends. Applying the 45ssl sealant was the fastest and easiest part of the whole project.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Before and after:
    May 2011
    Los Angeles, CA
    228
    Wow! Thanks for the pictures!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Nice job. I'm going to have to do the same thing down the road.
