Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: No Free Chlorine - Please help!
    Debjpools's Avatar
    Jul 2014
    Wallkill
    23
    Since I opened the pool in June/2014 (13,000 gallons above ground) Test results have showed No Free Chlorine. For last 4 years have used BioGuard products and never had this happen. Pool place told me to add 28lbs (over $100) Super Shock or drain water and start over. Water was clear & good for 3 weeks but as of last week No Free Chlorine again? Now they are telling me to add 15 lbs of Super Soluble also $100. Is they any other less expensive ways to bring up free chlorine? Can someone please help me with this problem. As of today, water looks clear and just a little haze.
    Jul 2014
    Clermont Florida
    56
    Re: No Free Chlorine - Please help!
    Welcome to trouble free pool
    We recommend buying the TF-100 test kits from TFTESTKITS.NET
    Dont listen to the pool store, they dont know about most things, how do you usually chlorinate your pool( pucks? ) learn from my mistakes pucks are horrible now my CYA is through the roof but im dilluting my pool with rain water and evaporation. If you tell us what your primary chlorinating source is that would be great and also order a TF-100 and give us your results
    Debjpools's Avatar
    Jul 2014
    Wallkill
    23
    We use BioGuard 3 steps system and I have Hayward sand fliter.
    Quote Originally Posted by Tristan View Post
    Jul 2014
    Clermont Florida
    56
    Specifically though, do you use the smart sticks? tell me everything you use to chlorinate your pool
    Debjpools's Avatar
    Jul 2014
    Wallkill
    23
    Smart Tabs, Back up and Smart Shocks
    Jul 2014
    Clermont Florida
    56
    How many tabs do you usually use per week?
    How many times do you shock per week or per month or whatever?
    Please add all of your pools information to your signature by going to your settings
    Debjpools's Avatar
    Jul 2014
    Wallkill
    23
    2-3 tabs per week, 1lb Smart Shock per week and 3 oz of Back up
    Also picture I posted was how pool looked last year. Do you want to see more recent pic?
    Jul 2014
    Clermont Florida
    56
    2-3 tabs wow im gonna guess your CYA is very high, im sure other members would also say that
    A pic would be great
    Order that TF-100 i was skeptical at first to but that thing has turned my pool into an oasis, with a little hard work you can get your pool back to normal
    Debjpools's Avatar
    Jul 2014
    Wallkill
    23
    What does CYA stand for?
    Pool installed 2000
    13,000 above ground Doughboy Pool
    Hayward Sand Filter with Matrix 1.5 hp pump
    BioGuard Step 3 System
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Welcome to TFP.
    CYA is cyanuric acid. Commonly sold as stabilizer. Using stabilized chlorine ads CYA to your pool. The amount of chlorine you need depends on your CYA.
    Start with ABC's of pool water chemistry here: http://www.troublefreepool.com/conte...ater-chemistry
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Oct 2013
    Chapin, SC
    1,141
    Cyanuric acid, Stabilizer. It's used to counteract the sun's burning of chlorine. Some is absolutely necessary, but too much is a bad thing. Most of us here use the trouble free pool system of maintaining our pools, and either use liquid chlorine ( common bleach), or a swg for FC and other chemicals we can buy at Walmart or a nearby hardware or grocery store. Usually for a lot less money than we we would be spending at a pool store.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Debjpools's Avatar
    Jul 2014
    Wallkill
    23
    Thank you all who have answered so far. I am just trying to figure out how much liquid bleach I should put in to raise FC of 0 to a 2 or 3? I have never used liquid bleach before and last time water was tested CYA was 91. I have approx 13,000 gallons of water pool is round above ground 24 X 24 4 feet deep.
    Pool installed 2000
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Debjpools View Post
    PoolMath will calculate doses for you. Link in menu bar at top of each page. Let us know if you need help.
    Welcome to the forum
    You're done SLAMing when:
    Debjpools's Avatar
    Jul 2014
    Wallkill
    23
    ok, now with PoolMath. approx 2 qts of Bleach?
    Pool installed 2000
    Jul 2013
    Gilbert, Az
    116
    With a cya level of 91 you will need to keep a much higher fc level than a 2 or 3
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
    Debjpools's Avatar
    Jul 2014
    Wallkill
    23
    New test today CYA level was 100 how much liquid bleach 8.25% do you think is needed to bring up FC level to 3? Also after adding it when is it safe to go in pool?
    New test today CYA level was 100 how much liquid bleach 8.25% do you think is needed to bring up level to 3? Pool Math says 2 quarts 1 cup 6oz does that sound right? (I never used Bleach before?)
    Pool installed 2000
    Donldson's Avatar
    NW Ohio
    2,916
    Whatever PoolMath is telling you to to add to get to 3, that should get you to around 3 assuming you correctly entered your pool volume and nothing is immediently consuming the FC.
    May I ask, with a CYA level of 100+, why are you only raising your FC to 3?
    Here are a couple of links to explain why I ask:
    FC/CYA chart
    ABC's of Pool Chemistry
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,608
    WELCOME!
    You are off to a good start! Finding TFP is the way to a CHEAP and clear pool!
    Your second step to taking control of your pool and wallet is to buy a good test kit. A link to the test kits that really get the job done are below in my siggy.
    This is one of those times where spending a little money will save you LOTS of money (and time) in the long run.
    The links listed by the people above me a wonderful links to help you understand the whys and what of your pool.
    See the pool store will test your pool for FREE! So nice of them (sarcasm). See it is not so free as most of the time the tests are wrong AND they will sell you all kinds of stuff to help your pool.
    Most tests for CYA do not go above 100 so there is no telling just how high it is. If your CYA is too high your will never be able to get ahead of it. The only way to lower CYA is to drain the pool but it is very important to know just how high it is.
    My old pool was ruined from HIGH CYA I trusted the pool store. Now I now better.
    Hugs to you! Let us know if there is any other way we can help you.
    Kim
    Debjpools's Avatar
    Jul 2014
    Wallkill
    23
    These are the last results from pool store:
    Temp: 76,
    Saturation Idx:0.2,
    TDS: 500,
    CYA 100,
    Tot Chlorine 0,
    Tot FC: 0
    PH: 7.5
    Tot Alkalinity 147,
    Adj. Total Alk: 117
    Total Hardness: 225.
    Bromine is still in pool.
    I need to do something now while I wait for my test kit to be delivered.
    Also can I go in pool right after adding Bleach?
    Pool installed 2000
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,608
    I wait about 30 mins to get is mixed in good.
    You can swim up to SLAM level. Here is the CYA/FC chart just in case you have not seen it.
    http://www.troublefreepool.com/conte...art-slam-shock
    Kim
