Results 1 to 7 of 7
Thread: Looking for suggestions for the best above ground pool ladder/steps......
    WitchyD's Avatar
    Jun 2014
    Tennessee
    10
    We put up the Intex Ultra 22' above ground pool last month. We are planning on building a deck and I'd like to get some pool steps. Do you have some you love? I'd love to see pics and links to where you got yours! Thanks for sharing!image.jpg
    Casey's Avatar
    SW PA
    10,433
    Re: Looking for suggestions for the best above ground pool ladder/steps......
    I bought my 38" Mighty Steps online. You can plug Mighty Steps into Google and find them online to order.
    I now have them bunge'ed to the lip of the pool which is perfect!
    Aug 2011
    Augusta, Kansas
    88
    We have a conifer ladder. I will add that we added more screws to the bracing to the bar bracing the legs. Easy to put together ...done by a 17 and two 12 year olds. It is the one with the rolling cover for the steps.
    Diane
    15,000 salty gallons - 24' x 12' x 52" Intex Ultra Frame Pool
    Intex Sand Filter, Pump, SWG - TF-100 and speed stir
    WitchyD's Avatar
    Jun 2014
    Tennessee
    10
    We bought these......just opened our pool today and plan on building the deck soon, so no "in use" pics yet.
    22'x52" 10,472 gallon AG Intex Ultra Frame pool on a sand base, Intex Sand Filter 3000GPH Pump, Intex Krystal Clear Saltwater System, Pool Devil Pro Skimmer
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by DianeF1 View Post
    I have the same ladder.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    WitchyD's Avatar
    Jun 2014
    Tennessee
    10
    How do you like it?
    Mar 2014
    Gulf Breeze, Florida
    66
    I don't have an Intex now but when we did, the original steps lasted 2 years before rusting. I rebuilt them using PVC pipe reinforced with rebar and then filled with epoxy to protect against rust. I re-used the original rungs.
    That worked well for a couple of years then I built some new steps using composite decking (6" wide by 3/4" thick). It's completely waterproof and neutral buoyancy. I used 2 8 foot lengths for the side rails and 18" lengths for the rungs all fastened together using stainless steel screws. I added a 2 foot 'rung' to the bottom to spread the load out on the pool bottom. I bolted the ladder to the deck. It was very sturdy and I'm sure it would outlast the pool.
    Don't have the pool any more (or house) so can't post pics.
    Chris Hawkins
    18,000 gallon vinyl Inground. Hayward Goldline Aquarite 40k SWG, Pentair Intelliflo VS pump.
    Polaris 3900 cleaner, Pentair Tagelus sand filter. AquaPro 1300 heat pump. TF-100
