Results 1 to 13 of 13
Thread: New pool...test results
    Jul 2014
    STILLWATER,NY
    47
    Had a pool installed last Tuesday....got it filled and all plumbed finally yesterday.
    Took my readings , used pool math to get the proper levels...
    Added 19lbs of baking soda to raise my TA....it was 2ppm, now 110ppm. Is that level ok? I have read anywhere form 80-120ppm is ok, but pool school recommends 90ppm.
    My ph was 7.2 at fill and I haven't done anything with that as baking soda will raise ph a bit, but how long should I wait before I add borax?
    I appreciate the help.....I never really payed attention to water balance as I do now , and I realize how much chlorine I burned through every season !!
    18,500 AG, VINYL..27' ROUND.. HAYWARD 24" SAND FILTER W/ HAYWARD 1 HP POWERFLO.
    Re: New pool...test results
    Your TA should be fine at 110. If you find the PH going up quickly, which is unlikely, you will want to lower TA. But otherwise leave it alone.
    Now that you have raised the TA, you should measure the PH again and see if it needs adjusting or not.
    Do you know your CYA level?
    Jul 2014
    STILLWATER,NY
    47
    Cya...best I can tell is about 30.
    Still says ph is 7.2 so I will.grab some borax.
    Thanks
    Jul 2014
    STILLWATER,NY
    47
    Well, after adding bleach and baking soda and stabilizer in my new pool yesterday....24 hrs later :
    FC= 1.5
    PH= 7.5
    TA= 110
    CYA=30...best I can tell...crappy HTH basic 6 way kit.....good one ordered !!
    My question is, why did I lose so much chlorine over night?? The sun today? Or is the CYA not kicking in all the way, I added 4lbs dissolved in warm water to a slurry...not much solid was left, maybe a cup.
    I added another 80+ oz of 8.25% bleach tonight to get the level back up. Will the FC level even out eventually so I wont use so much bleach?
    Thanks again for the help
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    How did you add/dissolve the CYA? It is not recommended to have undissolved solid CYA sitting on your liner.
    What was your starting FC?
    Jul 2014
    STILLWATER,NY
    47
    I dissolved the CYA in warm water...99% was completely dissolved ....maybe a cup granular , poured slowly into my skimmer.
    Pool was filled and chemicals added sunday...starting #'s were as follows:
    FC=5.0
    TA=110
    PH=7.2
    CYA= 30
    24hrs later(monday) the FC had dropped to 1.0 and the PH seemed to be up @ 7.5
    I know the CYA level takes a while to level out so...
    Jul 2014
    STILLWATER,NY
    47
    Day 3 of new pool fill...
    FC=1.5
    PH=7.5
    TA=110
    CYA=30-40
    added another 70oz of 8.25% bleach today....is it normal to add so much bleach daily or am I doing something wrong??
    Do I need more CYA....maybe put a few pucks in the floater?
    Thanks for the help
    38,242
    70oz is adding 2.5ppm of FC to your pool.
    It is normal to have to add 2-4ppm to your pool everyday depending on sun exposure, etc.
    So, seems pretty normal ...
    But, you need to target higher so that you are not dropping below the minimum in the FC/CYA Chart
    Jul 2014
    STILLWATER,NY
    47
    So basically raise my target in pool math according to the chart which @ a CYA level of 40....my target should be 5.0 FC ?
    38,242
    The most important thing is not dropping below the minimum which is 3ppm. So I would target 6ppm each day and verify that is stays above 3ppm the next day.
    Jul 2014
    STILLWATER,NY
    47
    k...thanks. I will give it a shot for a few days and see what happens
    Jul 2014
    STILLWATER,NY
    47
    Here is my PH.....looks high to me....7.5 yesterday...any reason it would go up or is my eyesight bad... I raised my target FC to 6 to see if it will stay above 3.
    38,242
    You need a better background for color comparison. The pH usually has a tenancy to rise.
