Thread: Mystery
    Fort Worth, TX
    83
    Mystery
    Several nights ago, I topped my FC off to 8 ppm.
    I usually do it every other day. It was reading 2.5 which is abnormally low. I tested it twice from water at different places in the pool.
    I added 10 cups of 8.25 bleach. So far so good.
    The next morning I tested again and read 14 ppm. I tested twice more and read the same thing.
    I had used a new bottle of bleach. I shook it and it had about what would be expected with 10 cups gone.
    I had not mistakenly added bleach twice the night before.
    That night it read 9 ppm. That is a loss of 5 ppm which I have never witnessed before.
    Over the next few days it behaved as it always has- no strange readings.
    To save my life, I can't explain what happened. Bad tests is the only possibility and I double and triple checked them.
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
    Re: Mystery
    FC going up to 14 is a mystery. Nothing comes to mind.
    FC loss is always a percentage of the starting level, so it is normal that you will lose more FC when the starting level is higher.
    Jun 2014
    Central Florida
    36
    Re: Mystery
    I wonder if it is ever the case for a bottle of bleach to be an abnormally higher % than the label says.
    22,000 gallon in ground, gunite, Hayward pump 1.5 hp and 36sq DE filter. Pool installation date unknown, at least 10 years. Screened enclosure.
    Fort Worth, TX
    83
    Re: Mystery
    That's what I wondered.
    After using the rest of that bottle, it appears to be the correct strength.
    Fort Worth, TX
    83
    Re: Mystery
    error post
