Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Mosquitoes are killing us!
    Darlene13's Avatar
    Jun 2014
    Winnipeg, Canada
    155
    Hi, everyone!
    The mosquitoes are attacking us as soon as we step on the grass. We have lots of trees and a big yard. Those small lanterns are not enough for our area, so I'm looking at one of those propane units, something like: Blue Rhino SkeeterVac, Mosquito Magnet, Koolatron Guardian Pro Biteshield. If anyone has units like one of these or a similar one, please give me your feedback on pros and cons, and whether it actually works!! Our summers here are so short to have them not be enjoyable, and I'm just fed up with all the bites!!
    Thanks!
    24' Round Above Ground Pool - 50,000 litres (13,200 gallons), 1 HP Hayward Ultra-Pro LX Pump Model #SP2290, Hayward Pro Series High Rate Sand Filter Model #S210T2, Hayward Chlorine Feeder Model #CL200EF, Enersol Solar Panels, Taylor K-2006 Test Kit
    Back2BasicsMom's Avatar
    Jun 2014
    Central MN
    19
    Re: Mosquitoes are killing us!
    We use the lawn spray by cutter or Off that hooks onto your garden hose 2-4 times over the summer. It has worked pretty well and we can stay out till about 10pm without being bothered too much. We had a propane skeeter trap and had lots of problems. Replacement parts are expensive. We decided it was not worth the expense to run it. I am in Central MN
    18' x 48" Above ground Intex metal frame 6,423 Gal
    Purchased Used (Approximately 3 years old) but new to us.
    110-120 volt Filter Pump with 1,500 gallon (5,678 L) per hour flow rate (Intex)
    Water is from a well
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    These mosquitoes are coming from stagnant water somewhere. I live in the desert so this is not hard to figure out. however if you can find the sourece I believe 70% of your problem is solved...... Wiothout finding your source you will probably need to spray your grass/shrubs/landscaping at least once a week. I hope it works out for you.
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    Have you thought about installing a Bat house? One bat can eat 1200 mosquitoes per hour.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Back2BasicsMom View Post
    I've used similar products with good results. Spray those plus tiki torches for minor help and ambiance works well. Canada can be much worse than even here for mosquitoes and flies in the summer. I learned that on a few fishing trips to Manitoba.
    Isolated Spa - 345 Gallons
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    I used this
    http://www.amazon.com/Yard-Spray-Con...tic+yard+spray
    worked very well for our mosquito problem. It's intended for ticks, but works wonders for mosquitoes.
    Our mosquito issue made our backyard nearly useless. now I still use off or similar, but it's at least tolerable. For a week we had no mosquitoes. I need to mow some grass down...might help.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by JVTrain View Post
    I thought I knew what mosquitos were until I went fishing in Canada. I had no idea how bad they can be.
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Bats! Bat guano has been confirmed as the source of MERS and SARS... I'll skip the bats...
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Next time you take a fishing trip to Canada, try Labrador. The fishing is awesome, but the black flies can make you suicidal. Un-frickin'- believable !!
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    I bought one of these a few months ago, and it really has cut down on the amount of mosquitos and another bugs we had...
    http://www.amazon.com/Flowtron-BK-15...overage&dpPl=1
    Jun 2014
    Walkersville, MD
    30
    I'm thinking about getting one of these: http://www.amazon.com/gp/product/B00...erToken=Obidos
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    The first thing I would check for is stagnant water somewhere nearby. An often-overlooked source is clogged gutters. I had this problem at my former house which also had lots of trees on the lot. Once I got on the ladder, found that I basically had a stagnant river in my gutters. Once I removed the clog, the water was able to drain and the mosquito population decreased noticeably. If this turns out to be the problem, you may look into some sort of gutter-guard product to keep tree debris from accumulating in the gutters.
    Another angle on dealing with this problem is to consider the use of natural repellents. Here are a few ideas that not only work, but have been found to be more effective than commercial chemical insecticides in repelling mosquitos:
    1. Catnip—According to research at the American Chemical Society, the essential oil found in the herb catnip is about 10 times more effective than DEET in repelling mosquitoes. (http://www.sciencedaily.com/releases...0828075659.htm)
    2. Citronella—I'm a fan of the old-school citronella candles. Use only pure essential oil of citronella—not fragrance oil. Citronella can also be applied topically, however make sure to use a high quality citronella essential oil from a natural food store. While it’s not as effective as catnip, it’s still a good option.
    3. Neem oil or Neem Seed oil: According to a study by the US National Research Council, Neem oil is more effective than DEET. The results were confirmed by scientists at the Malaria Institute in India and in research cited in the Journal of the American Mosquito Control Association. (http://www.researchgate.net/publicat..._indica%29_oil)
    4. Organic soy oil—Research cited in The New England Journal of Medicine found that repellents made of soybean oil are just as effective as DEET-containing repellents.
    Read more here: http://thelittlegreenapple.com/artic...epellents.html
    Other essential oils that make good mosquito repellents include Lemon Eucalyptus Oil, Cinnamon Oil, Rosemary Oil, Lemongrass Oil, Cedar Oil, Peppermint Oil, Clove Oil, Geranium Oil.
    If you plan on applying any of these topically, I would first apply a small amount in a localized area as a test to see if you have an allergic reaction. If no allergic reaction is found, then I would suggest mixing the essential oils with a carrier such as a thin oil, witch hazel, or vodka (though I can think of better uses for the latter). This will make a good spray product. Avoid using plain water since oil & water do not mix. You can also apply these products to cotton balls and place them in a small wide-mouth jar or similar implement. I have done this with peppermint oil and it has definitely made a difference.
    Since you live on a wooded lot, you will always have more of a mosquito problem than those who live on an open lot. Try wear lighter-colored clothes when you will be on the patio especially from late-afternoon through dusk. Mosquitos are attracted to darker colored clothes since it resembles foliage to them and, since most mosquitos do not like direct sunlight, they will seek shade.
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Great info Bo!
    I have also read some good feedback with regard to this product: http://www.amazon.com/Mosquito-Barri...osquito+gallon
    I've been tempted to try as we are on two acres and surrounded by other farms... which I am sure have standing water.
    This year has been especially bad with all of the rain we've had.
    The bug zapper and tiki torches help. But last Saturday night swimming nothing seemed to keep them away.
    They were out with a vengeance!
    ArnoldNagy's Avatar
    Jun 2012
    Ontario, Canada
    9
    Quote Originally Posted by Waldog View Post
    Great info Bo!
    I've used this product before and it definitely works. It's made from concentrated garlic and is very safe to use around kids & pets. If you use it regularly the effect improves. It also works best if you start early in the season before the Mosquitos get really bad. Or at least that's what I've read, I never remember to use it until we have an infestation.
    Arny
    27' Round, 16,500 gal, AG, installed July 12, 2013.
    Splapool 1HP pump, Distinction 20" sand filter 200 lbs, Feherguard solar cover & reel.
    Titan III Heat Pump.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,028
    I use Mosquito Barrier too. Works great.
    I also have used Dr. T's Mosquito Repellent granules that I got at the Feed Store. Its all natural, just sow it around the yard by hand and you're done. Works almost as good as Mosquito Barrier.
    I haven't been bit but maybe twice in the last month.
    Great info Bo!
    Divin Dave,
    Hi. So we are in a heavily wooded area and Mosquitos are a huge problem for us. We have tried almost everything.
    - in the Spring when it's more rainy, I throw Mosquito Dunks in the wetland/pond areas near our house to help control the larvae. No idea if/what impact these have, but I have faith!
    - Skeeter Vac - simply didn't work and we spent a LOT of money on propane.
    - Dynatrap - bought 2 of these this year. They do catch a lot of bug, mostly moths, but not enough Mosquitos to be worth it.
    - Mosquito Squad - did this one season (professional spraying every 2 wks), it works very well for 3-4 days, but they only spray every 2-3 wks, so you can figure out how that goes. And it's very expensive. When we had our big summer party , they came over the day before and did an additional garlic treatment, so our backyard smelled like an Italian restaurant (which I like, but not for an August Summer cookout), and I have since read that the whole garlic theory is ineffective.
    - Tiki torches - we have about 8 of these surrounding our pool area, and we use BiteFighter fuel. I still feel this is one of the best deterrents, but takes a lot of messy effort to refill them throughout the season.
    Bottom line is that it's a constant battle that needs to be fought on many fronts. We still run the electric Dynatrap, light the tikis every night, use the zapper tennis racquets during the witching hour, and use Off spray on the bad nights (the dry formula is much more tolerable). And we are considering getting a couple old fashioned bug zappers, which I have a feeling will be the most effective. Oh, and on the nights that we light the fire pit, that seems to be the most effective. Good luck!
    10k gallon fiberglass freeform pool, Paramount SwingJet system, Dolphin DX5 robot, Pentair 48" Tagelus sand filter with glass media, WhisperFlo 1 HP pump, Hayward H200FDN natural gas heater, TF-100 Test Kit, and, of course, Margaritaville Tahiti blender!
    Aug 2010
    Dallas, TX
    4,052
    The chances of getting sick from a bat are almost zero. For example, the CDC states 1 to 2 people per year contract rabies from bats in the US. I have lots of bats around my pool, all they want to do is eat mosquitoes and stay away from me and my dogs. I just wish I had about 100 more.
    Bug zappers attract more bugs than they kill. And they kill beneficials.
    A good fan is about the best thing I've found.
    Good point on the fan. We have one in our pergola and it seems to help quite a bit. That said ya can't cover your whole backyard in fans (at least we can't). We've always considered the bathouse thing, but I've heard it takes several years for it to have an impact. ?
    May 2013
    Needham, MA
    140
    Domo,
    Sent you a PM.
  20. Back To Top    #20
    Feb 2014
    San Antonio, TX
    12
    I'll second the recommendation for Dr. T's... We put that stuff on some areas in our yard and the mosquitoes just stopped. Doesn't smell bad either.
