Thread: Skimmer drains down, normal or cracked?
    Jun 2013
    South Florida
    118
    Bought the house a little over a year ago. Always noticed after heavy rains that the pool level drops back down to the lip inside the skimmer. I circled it in red on the photo. Is this an intentional gap built in the skimmer to prevent over flow? Or has the plastic separated and it is now just a leak when the pool level gets really high?
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
    bproosow's Avatar
    Apr 2014
    Auburn, CA
    41
    Re: Skimmer drains down, normal or cracked?
    That water level looks really high, and it looks to be going over the top of the skimmer. Your water level should be about halfway up the opening from the pool to the skimmer. Any higher and the skimmer won't be effective because nothing will float through the opening to get into it.
    20K gallon (?) in-ground gunite pool and spa with (yet to be identified, I believe it's Pebble Fina) finish. Jandy LX gas heater, solar heat, Jandy cartridge filter, Polaris 360 cleaner (with energy filter, no booster pump), dual Jandy stealth pumps (one primary circulation pump and one for spa jets), Jandy Aqualink RS-8 controller with PDA, Pool Cover Specialists automatic cover. Taylor K-2006C test kit.
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    Did the water have enough time to evaporate by any chance? Was there anything that could've caused a little of the water to splash out?
    Bobby (my pool)
    18,000 gallon in ground/white plaster
    Flotec pump/Aquatech MYB100 single cartridge filter - runs 6 hours/day in evening during summer
