Thread: full test results
    Jul 2014
    Hudson, wi
    81
    full test results
    I finally did a complete test and here are the results, question is everything seems to be working good, do I need to make adjustments?
    CH- 175
    TA- 90
    PH- 7.3
    CYA- <20
    FC- 6 had people over yesterday and put a full gallon of 12% in after, guess I didn't need that much.
    CC- .5
    I get less than 2 hours of sun a day and it isn't the entire pool so I wasn't sure if I need to mess with the cya. I use about 1/2 gallon of 12% a day. Thanks
    21,000 gallon IG with vinyl liner, Pentair sand filter, TF100 test kit, pool is about 15 years old.
    new in 2016 - Hayward SWCG with T15 cell
    Butterfly's Avatar
    South Carolina
    10,045
    Re: full test results
    My only suggestion is to increase CYA to at least 30, maybe even 40 since you have a sand filter.
    <20 seems too low for an outdoor pool, especially since we recommend 20 for an indoor pool!
    You're done SLAMing when:
