Thread: Air bleed stripped, need new gauge..... Which one?
    May 2014
    Windham, NH
    101
    Discovered today that the air bleed under my gauge is stripped. Gauge appears to be old, came with filter I assume.
    I see gauges on tftestkits, do they come with the bleeder valves as well? If not which one should I install?
    25k Gallon IG, Vinyl liner, In Floor Cleaning System, Jacuzzi Earthworks DE 75 filter, Hayward H Series Propane Heater, TF-100 Test-Kit
    Casey's Avatar
    SW PA
    10,457
    Re: Air bleed stripped, need new gauge..... Which one?
    Welcome to TFP!
    Lets get this bumped to see if we can help get an answer to your question.
    38,521
    No, the gauges are just the gauge.
    Sounds like you need part of the filter.
    May 2014
    Windham, NH
    101
    I was afraid you would say that. Is the air bleed part of the top half of the filter cover and can not be replaced by itself?
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Looks to be around $30 on Amazon ... Just type in Jacuzzi Earthworks DE 75 air bleeder valve
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
