Results 1 to 7 of 7
Thread: I have been on the BBB method this year, and need to bump my TA up a bit. I have...
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    ...some Baquacil PH Increaser still on hand from my time as a Baquacil user.
    Can I use the Baquacil PH increaser in my pool without messing anything up?
    Thanks!
    20K gal, IG vinyl, Waterfall on 2nd pump (1HP US Motor), Dolphin cleaning system, Central Arkansas, installed 1999
    2 Haywood Super Pumps, 1HP (main and waterfall pumps), Purex Triton II (TR 60) Sand Filter (replaced original 2016)
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: I have been on the BBB method this year, and need to bump my TA up a bit. I have
    A quick search returns a MSDS indicating that it is just soda ash (sodium carbonate).
    Yes, you can use it without messing anything up.
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    Thanks Abigail!
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    Just as a follow up, I have used the Baquacil PH Increaser with success!
    Thanks again, Abigail!
    Oct 2013
    Chapin, SC
    1,141
    I assure you, 20 Mule team borax will increase pH the same at a whole lot less $$$$.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    May 2014
    584
    OP stated it was leftover from before conversion.
    Oct 2013
    Chapin, SC
    1,141
    Was merely pointing out if he needs pH increased in the future he needn't go to the pool store to buy the expensive stuff. While I'm editing my post, if he only needs to bump his TA without increasing pH as the op says, he can do that with baking soda also a whole lot less $$$$
