Thread: Feedback on my numbers?
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Pool is crystal clear & i don't want to mess up a good thing
    FC-3ppm
    Cc-.5
    PH-7.8
    TA--60
    CH-400
    CYA-45
    If I read the Pool Math Calc right I need to add about 117ozís of Baking soda to raise my TA to 80?
    Am I reading it right?
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: Feedback on my numbers?
    Yes, I get the same result when I input your details.
    I couldn't help but point out that your FC is below the minimum for your CYA level, I would suggest you add bleach immediately.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I agree with ^^^^^. Your FC is low.
    I would be using 50 as my CYA level and then targeting 8 and never let it fall below 4. That way your covered. When the CYA level is like yours, in between, I like to round up.
    About your TA. How does your PH behave ? Is it pretty stable or does it rise ? 😎
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    The CSI is good. If your pH is stable, I'd leave it alone. If it ain't broke, keep fixing it until it is!
    Jun 2014
    Long Island, NY
    340
    PH stays between 7.2/5 and 7.8-
    I did throw is a couple of ‘Used up” A&H Fridge BS Boxes, 2 lbs, early last week which I guess was enough to push to the 7.8
    I’m with you Richard, I think I’ll let the PH alone for a while since I check it daily anyway
    So with my CYA @ 45ish I should push my FC to 6 or 8?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Like I said, I like to round up to the next level if the CYA test falls in between. That way your covered for keeping your FC in a good range so you don't have an algae bloom. If you go with CYA at 50, FC level is a target of 8 and never below 4. If you go then next level down at 40 it's 7 and never below 3. 😎
    Jeff
