Thread: What is that material called between the coping and the pool deck
    Apr 2011
    Austin Tejas
    4
    From what it appears there is grout between each coping piece, but there is something else that appears to be a rubber/elastic material that goes in the expansion join between the coping and the concrete pool deck. What is this called and can I get my grubby little DIY hands on some in a retail store?
    16x34, ~20K gal, vinyl, 1 HP Super pump, SwimClear Cartridge filter, Aqua Rite SWG
    737mech's Avatar
    Jun 2013
    Corinth,TX
    148
    Re: What is that material called between the coping and the pool deck
    I believe you are referring to Deck o seal.
    http://www.amazon.com/gp/aw/d/B004BV...&robot_redir=1
    Finally completed March 2014
    IG 27,300 gal 35'x16' 3.5'/5.5'/8' diving pool, Pentair Intellichlor IC40, De FNS 60, 3HP Intelliflo VF pump, Easy Touch 4, Kreapy Krauly Platnium, 3/4 Hp booster pump, raised stone wall w/ 2 stone scuppers, Stonescapes aqua blue mini pebble plaster
    Apr 2011
    Austin Tejas
    4
    That looks like what I need - thanks!
    mas985's Avatar
    Pleasanton, CA
    11,737
    It is call pool mastic. Deck-O-Seal is a brand of mastic.
    Mark
    Jul 2013
    Waxahachie, Tx.
    442
    Also called an expansion joint sealer
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
